FS: turbo Dart 347 ranger
347 Dart iron eagle block
Forged internals eagle rotating assembly and probe pistons 8.5 compression
Solid roller cam and comp solid lifters
Comp gold 1.6 roller rockers
trick flow stud girdle
Dart pro 1 aluminum 195cc heads dual spring
Dart sheet metal valve cover
Edelbrock efi super victor + 90deg elbow
Acufab TB
aermotive A1000 pump + fuel pressure regulator
75 lb injectors
Classic FAST-- sequential
MSD dist
HVC II coil
Custom turbo kit air-water
Metzier water pump /air to water
Turbonetics t-70 mm turbo
Tial 38mm wastegate
Tial 50mm BOV
ART CARR 1000 hp C4 manual valve
ART CARR 3500 converter
B&M billet street bandit shifter
Custom 4- link
Ford 9 inch
389 gears
Centerline split spoke 17x7 front
Centerline split spoke 15x10 rear on mickey drag radials
Autometer Cobalt tachometer with shift light- trans temp and boost gauges
G-force 3 inch 5 point harnesses (need installed)
Here is a link to build thread-- http://truestreetcars.com/forums/pro...ck-ranger.html
Questions call or text 575-420-0893
SOLD SOLD
Acufab TB
75 lb injectors
MSD dist
HVC II coil
Tial 38mm wastegate
Tial 50mm BOV
Custom 4- link
Ford 9 inch
389 gears
SOLD SOLD
lxcoupe
09-06-2017 08:24 AM
