Turbo 2004 ecsb
Turbo 2004 ecsb
I am thinking about selling my 2004 Silverado. I have a lot of money tied up in this but I am thinking about a new project. Truck made 634/601 at 15lbs on 110 octane with a conservative tune by speed inc. The truck has only been driven on 9 lbs since built and runs very well for the street.
Engine-
Stock 5.3
Arp rod bolts
Arp head studs
Ls9 head gaskets
Melling high volume oil pump
Ls2 timing chain
Arp cam bolts
Speed inc tu0 cam
Pac 1519 springs and hardened pushrods
Holley mid rise intake
Ls3 throttle body
Xlink
Arp balancer bolt
Fuel-
Id1000 injectors
Aero motive boost reference regulator
Twin walbro fuel pumps (2nd pump on Hobbs switch)
-10 feed and -6 return ptfe fuel line
Fuel system was made for e85 but never made the switch
Both pumps have individual Hotwire kits
Turbo-
S480 t4 flange with race cover 1.25 ar 83/74
Custom hot side and cold side built
3" inter cooler piping
Tial 50mm bov
Tial mvr 46mm wastegate
Turbosmart eboost street boost controller
Aem fail safe gauge reads boost and wideband
Treadstone trstp9 inter cooler rated for 1300hp
3-4" down pipe with 4" exhaust to rear axle using 32" magnaflow diesel muffler
Transmission-
4l80 with jakes level 4 rebuild kit
Tubular crossmember
Circle d triple disc lockup 36-3800 stall converter
4l60-4l80 conversion harness
Custom steel 2pc driveshaft
Tru cool 40k with braided hose
Rear end-
Motive performance 3.73 gear set
Trutrac
Misc-
34" radiator with oem electric fans using Nelson harness
Rear disc brakes converted using 1320 wheels bracket to fit 15" wheels
15x10 Cragar soft 8 wheels with 275 60r15 et street ss tires
Front 17x7 Cragar soft 8
Wheels/tires and brakes brand new less than 100 miles on them
Brand new in box Calvert racing caltracs for flip kit
Djm 4/6 drop using control arms up front with bell tech street performance shocks up front and flip kit and bolt in notch with djm shocks in rear
Msd 2 step
Have 4 oem ss wheels powder coated black with 2 good tires to go with the truck as well.
I'm sure I'm leaving some things out but this covers most of it. Pm for more info and I will give my phone number to serious buyers as I am currently out of the country for a few more days.
I would like to get 15,000 firm for the truck, I am not in a financial situation to take less offers and I have well over this in parts alone.
Truck has around 130,000 miles but has less than 5k on all parts listed and some with even less as I built this as parts were needed.
Engine-
Stock 5.3
Arp rod bolts
Arp head studs
Ls9 head gaskets
Ls2 timing chain
Arp cam bolts
Speed inc tu0 cam
Ls3 throttle body
Xlink
Arp balancer bolt
Fuel-
Id1000 injectors
Turbo-
Tial 50mm bov
Transmission-
Tubular crossmember
Rear end-
Trutrac
Misc-
Msd 2 step
There is no catch haha I love this truck but I have been thinking about getting another car, I'm sure if it was spring time I wouldn't be thinking about selling at all.
vVandals909
13
04-12-2019 10:31 PM
