WTT for rcsb 99-07 chevy or gmc with some mods
I have a 98 ss camaro
383 ls6 block lunati rotating assy.
gtp stage 3 ported heads
comp roller rockers
fast intake
90mm nick williams throttle body
all arp wardware
elec. water pump
howe aluminum rad with twin fans
f-1 procharger with cog belt
huge intercooler front mount
kinsler billet fuel rails with 96 pound injectors
-10 and -8 braided fuel lines front to back
ricks stainless gas tank with dual a-1000 pumps in tank
built powerglide with brake 3800 stall
12 bolt moser with 4.10 gear with rear load cover eaton posi
rear wilwood brakes with parking brake
front to rear bmr suspension tubular k member control arms torque arm drag rear sway bar ssp rear lower control arms trans cross member and much more
double adjustable struts on all four corners
wolfcraft 6 point cage tigged in
boost, water temp, trans temp, fuel pressure, oil temp guages
wide band hp tuners car has 2000 model wiring harness
kooks headers with stainless y-pipe
and much more looking to find a nice rcsb with some mods 99-07 chevy or gmc pick-up will also sell car rolling or how ever you would want it if intrested let me know thanks
comp roller rockers
fast intake
all arp wardware
elec. water pump
It's really pretty streetable the power steering was removed to put a brace for the procharger the guy that had it before me took the air and the 6 speed out of the car I want to put a 6 speed back in the car and that wpould make it very streetable I had it in florida last month it was 105 in the shade and the temp never got above 180 deg. I was told it made 800 at the back tires with 10 lbs of boost and the pulleys have been changed but hasen't been back to the dyno yet I don't have any time to mess with the car anymore and I really need a truck
ARC
57
02-21-2022 10:54 AM
RoidedSS
08-11-2015 11:51 AM
