05 Yukon XL 5.3 (vin Z) to LQ4/9 swap w/ E85...
Hope someone can shed some light here...
A friend has a 05 Yukon XL, flex fuel 5.3 with the infamous cracked 706 heads. We're replacing the engine (knocks like hell now) and the guy wants to drop in a LQ4 or LQ9 instead of another 5.3 since he tows a camper often.
I know the engine swap itself is straight forward, there won't be any problems there.
The question is in the tuning... if we keep the old 5.3's E85 fuel system (injectors and all), can the tuning be easily done (i.e.- mail order) so that the LQ4/9 will run on either gas or E85 like the 5.3 did? Can the stock vin Z injectors (~35# correct?) keep up with fueling a basically stock 6.0 with E85?
I've searched and read other threads where 5.3s were swapped for 6.0s and all that was needed was a mail order tune. BUT, here i want E85 operation to be factored in.
Thanks.
Thanks.
Destroyer of Transmissions
Flex fuel has plenty of fuel pump and injector for a 6L.
When the fuel composition sensor goes out on the "Z" Tahoe, unplug the sensor and turn of the SES light in the tune like I did lol. You cant run E85 anymore but that sensor was $600 last time I checked.
