114-115% Idc :/
Old 11-08-2007, 08:51 PM
  #41
Moddoo's Avatar
Originally Posted by dirt_track_racer_81
didnt read all the posts but im kinda leaning more to your pump being bad than running out of injector..on my 5.3 and cam i was gettin 153% duty cycle i put an inline pump in and i was back down to 8x% duty cycle..i have 28lb ls1 injectors in my 6.0 now and cant remember what the duty cycle is but its not over 100 or i would have gone bigger..and i also set my fuel pressure to 60psi
Can you explain how a pump is related to the IDC?
Unless you made a change in the tune.
Old 11-08-2007, 08:54 PM
  #42
Hello Dave
dc_justin's Avatar
Especially with his Speed Density tune... There is no direct correlation except when in closed loop, and even then, it wouldn't go to that extreme...
Old 11-08-2007, 09:22 PM
  #43
dirt track racer 81's Avatar
pump going bad and running out of fuel causing the injectors to work harder??
if thats not possible i cant explain it though... a/f leaned way out and the motor would cut out realy bad..i made a post about this a couple years ago when this happend..put in an inline pump..a/f back to jivin were it should..it worked and that was all i cared about
BlackGMC
01-11-2013 02:53 PM
nonnieselman
32
09-02-2012 08:59 PM
05_quick4door
04-12-2012 11:00 PM
Trezent
03-02-2011 03:06 AM
BlackGMC
13
04-30-2008 09:10 PM
Quick Reply: 114-115% Idc :/
