1500hd wont shift into overdrive
i have a 2003 gmc 1500hd that wont shift into overdrive anyone have similar problems? i need to replace my bank 2 sensor 2 o2 sensor so i have a check engine light on, could that be throwing the truck into limp/home mode so it wont shift into top gear?
How do I change this text
check codes first. Once all are checked and fixed you can then go on to trouble shoot the trans. Misfire codes will not allow the Torque converter to lock which could be mistakine for no OD. you sure no OD?
