2 bar tuning
#22
The only other info I know on the MAP sensors. This info is from the HPT site....
www.SummitRacing.com
PN# MSD-2313 3bar MAP
PN# MSD-2312 2bar MAP
PN# MSD-2311 1bar MAP
www.GMPartsDirect.com
PN# 12223861 3bar MAP
PN# 16040609 2bar MAP
PN# 16137039 1bar MAP
heres some other GM stuff
1 Bar
GM part # 2503679
standard part # AS-5
2 Bar
GM part # 16009886
Wells part # SU-129
standard part # AS-4
3Bar
GM part # 16040749
1 Bar
GM part # 2503679
2 Bar
GM part # 16009886
Wells part # SU-129
3Bar
GM part # 16040749
#23
Originally Posted by dewmanshu
I ahve been screwing around with this alot lately...yesterday I changed it from 1 to 1.25. I am not having as much luck as everybody else. I do see the trends, but my trims move big time. At "1" I had average trims of -3 to +3 in most areas below 110kpa and when I moved it to 1.25 it went to lots of +'s, +5 to +7 in alot of areas. Then on the way home I turned the bias off. -7 to -12 was what I saw. HOLY crap. All IAT and this truck is pulling some fuel and closer to ECT and it is adding some fuel.
I thought the basis of this was more IAT temps more fuel. Which isn't always necessary. Mine is pulling tons of fuel with no "bias" at all. Hmmm.
Obviously going stft is the fix for anything under 110kpa, the pcm will fix it as per what it needs, but that confuses me as well, cause it isn't doing as the "theory" states with this bias.
"airmass = VE.MAP/MAT
airmass = grams/cyl
VE = grams.Kelvin/kPa
MAP = kPa
MAT = Kelvin
MAT is the estimated manifold temperature, which in earlier OS's is simply the IAT, but in later OS's uses the blending of IAT and ECT dependant on airflow. The issue seems to be worse in the earlier OS's due to this fact. If you don;t see the "Use Complex Model" setting then its just using the IAT, even though there may be a bias table shown it's not used."
-chris at hpt
MAT is really the only variable that changes based on weather but its also estimated not emperical WTF? This is where modeling comes into play. And it directly effects airmass. I wish I could walk through the steps but I dont know enough yet.
#24
Originally Posted by trever1t
Just a small (may be way off track) question for you about 2bar tuning. If it deletes the MAF from calculating A/F then what or how does the PCM compensate for IAT's and Altitude changes?
#26
Former Vendor
1 Bar
GM part # 2503679
2 Bar
GM part # 16009886
Wells part # SU-129
3Bar
GM part # 16040749
1 Bar
GM part # 2503679
2 Bar
GM part # 16009886
Wells part # SU-129
3Bar
GM part # 16040749
Originally Posted by Wilde Racing
This is a "plug and play" MAP for up to 15 lbs boost:
GM P/N: 12580698 AC Delco: 213-1631
2 Bar GM part # 16009886
GM P/N: 12580698
noproblems209
08-10-2015 06:57 PM
GMCtrk
07-17-2015 06:39 PM
