2 step question with LNC-2000
Old 08-30-2013, 12:54 AM
2doorfury's Avatar
Default 2 step question with LNC-2000
Is there a way to hook up the 2 step on a foot brake? Or does it only work on a trans brake or line lock?
Old 08-30-2013, 07:35 AM
Chevy_King1500's Avatar
you can put it on a momentary push button
Old 08-30-2013, 09:00 PM
2doorfury's Avatar
That's what I was thinking. What about one of those nitrous buttons that goes under the gas pedal. But instead put it under the break peddle??
Old 08-30-2013, 09:14 PM
kbracing96's Avatar
Yes, When I had one, I just tap the trigger wire into a hot wire on the brake light switch. Brake lights on = 2 step on.
Old 08-30-2013, 09:42 PM
Byrdman11's Avatar
And think the same as KB Racing.
Old 08-30-2013, 10:31 PM
oakley6575's Avatar
So you are able to run an arming switch to the two step? Then once you arm it, the brake pedal becomes the trigger?
Old 08-31-2013, 01:14 AM
2doorfury's Avatar
That's the impression I'm getting. That's how I was thinking it would work. The arming switch is put under brake peddle. When brake peddle is applied, 2 step engages. When let off it turns off
Three6GMC
08-27-2015 03:53 AM
lxcoupe
08-22-2015 08:23 AM
bighouse
08-14-2015 08:00 AM
hirdlej
08-10-2015 10:51 PM
USMCvet0311
08-01-2015 07:45 AM
Quick Reply: 2 step question with LNC-2000
