2002 8.1 alternator wires?
I'm trying to repair a 2002 8.1 truck wiring harness. I am 99% sure the alternator L terminal connects to PCM red 15. Can anyone tell me what PCM pin the alternator F-Terminal connects to?
Is it the same for a 5.3/6.0 truck as well?
Pretty sure I figured it out on my own, but if you wouldn't mind verifying that I'm correct, I would REALLY appreciate it. The alternator F terminal, which should be the grey wire from the alternator, goes to PCM C2 pin 52 (red 52) and the L terminal, which should be the brown wire, goes to PCM C2 15 (red 15).
The wiring diagrams I found for a 2002 5.3 liter Yukon are the same as the ones I found for a 2002 8.1 liter 2500HD.
SlvrSierra4.8
10-01-2015 09:39 PM
kalikid06
09-20-2015 07:46 PM
