2003 GMC Sierra 5.3 How do you know if you have stock Tune??
Old 11-05-2009 | 12:57 AM
gmcz71&G8Gt's Avatar
Default 2003 GMC Sierra 5.3 How do you know if you have stock Tune??
Hey Guys I have a 2003 GMC Sierra with a 5.3 that I just bought used. I was wondering is there away to verify if the vehicle is ruuning on the Stock Tune/Software? AS I stated I bought the vehicle used and I speculate that possibly the vehicle was tuned prior to me purchasing it? Is there away to confirm whether the vehicle is running on the stock orinal tune from Factory?
Old 11-05-2009 | 01:00 AM
charcold-bowtie's Avatar
have somebody with software pull the tune and compare it to a stock OS.
Where you located?
Why does it matter?
Old 11-05-2009 | 01:12 AM
Where you located?
Why does it matter?
I am from Maine. I was just wondering for my piece of mind so I know the history of the truck and whether it is or isnt in case i have issues
Old 11-05-2009 | 01:31 AM
GMCtrk's Avatar
the probability of it having anything other than the stock tune is almost zero, unless you have reason to believe otherwise.
Old 11-05-2009 | 03:22 AM
nickleahy23's Avatar
what are your shift points at wide open throttle? if its tuned, they should be quite a bit higher..also, does the tow/haul button act normal? as in rpms are higher during normal driving? or are they the same, but just firmer shifts, etc?
also look at the computer in the engine bay..if it was from a tuner like blackbear, wheatly, waitforme etc it should have a sticker on it..
Old 11-05-2009 | 07:36 AM
The Shift point are Higher and more firm also I looked around in the truck and found a manual for bullydog?? from the previous owner in the cab of the truck
Old 11-05-2009 | 10:29 AM
06MonteSS's Avatar
FormerVendor
aaaah... bullydog....
it's probably got a tune in it then... that's a programmer/tuner....
get it flashed back to a stock GM tune by a dealer before you use your Predator on it, or you'll have problems...
Old 11-05-2009 | 11:46 AM
How are the Bully Dog Prgrammers?? Is there reason for concern?? New to alot of this so not sure
Old 11-05-2009 | 12:29 PM
06MonteSS's Avatar
FormerVendor
predator's are better than the bullydog...
better tunes, more flexibility, more adjustability, etc etc...
Old 11-05-2009 | 01:07 PM
00ChevyScott's Avatar
Wearin' da big hat
predator's are better...
Do you work for diablo?
