2009 colorado v8
what is ASC? if your talking about the traction control and stability control this is how you turn if off with tracion control button but you have to do it every time you start the truck
if you press the traction control button once it disables the traction control, you will be able to spin the tires going straight but if you trun the steering wheel it will kill the power
if you press and hold the traction control button till it says STAB SYS OFF and TRAC OFF it will disable the traction control and stabili trac, then you can spin the tires going around turns or if your doing a burnout and have to turn the steering wheel it will not kill the power.
FlowmasterMufflers
09-18-2015 02:31 PM
