2bar MAP tuning
Old 10-17-2006, 11:41 PM
Notorious BIG
Holty's Avatar
Default 2bar MAP tuning
i'm meeting up with my tuner and we're going to work together on converting to a 2bar setup on my truck this weekend. anyone have any advice for me on this? tips or tricks?
Old 10-17-2006, 11:42 PM
Hello Dave
dc_justin's Avatar
My suggestion, keep the MAF in the system and just have it fail over when you pass a certain frequency. Your overall drivability (especially in throttle transitions) will be much better with both systems in play.
Old 10-18-2006, 05:55 AM
Bowtie70SS's Avatar
My suggestion is that you send me a copy of your tune when you're done so I can see what all is different. I gotta get my HPT cable in the mail so I can upgrade to the MPVI so I can log with my wideband and get some more credits to upgrade to 2 bar myself. I really like the idea of keeping the MAF as a failsafe. Would to descreen it as well to aid in airflow? It's probably not that much of a restriction anyway is it?
Dave
Old 10-18-2006, 07:03 AM
Moderately Differentiated
dewmanshu's Avatar
Dave
not really on the restriction. I didn't take notice where you leave, but I am mafless, but it is all intact so I can go back to it for emmissions.
I love the idea of maf for a little bit then have it fail, but I spent so much time tuning with out it, I just gave it up. I might do that when emmissions come around again.
My only advise, if you haven't taken up drinkin, you will.
Old 10-18-2006, 07:18 AM
2nd fastest 5.3 ECSB
trever1t's Avatar
This is how my tuning works.
Old 10-18-2006, 07:10 PM
m7 rocket's Avatar
Sorry to kind of hijack...
When you remove the MAF from the programming, it sounds like you guys are saying there is now NO fail safe. Do you mean if there was an issue with something the truck would not run properly and possibly self-destruct or not run at all kind of thing, or just a fail safe for drivablity issues and tuning errors?
Old 10-18-2006, 07:12 PM
Hello Dave
dc_justin's Avatar
It's not really a failsafe. With the MAF in play, when measurements exceed a certain level, the input from the MAF is deemed to be out of range and is to be ignored. At that point, the PCM will ignore the MAF input and "fail over" to the VE table exclusively for fueling.
With the MAF removed, you are always running off of the VE table.
Old 10-18-2006, 07:15 PM
m7 rocket's Avatar
Thanks
So do you know if this affects the stock fail safe, like when a sensor fails it will still run, just not as efficient as normal?
Old 10-19-2006, 07:11 PM
Notorious BIG
Holty's Avatar
hey guys, just realized, am i going to have to go vacuum mod for my tranny now since i'm going 2bar. i do plan to keep my maf so will this work?
Old 10-19-2006, 07:19 PM
dewmanshu's Avatar
never heard of such a thing.
Quick Reply: 2bar MAP tuning
