2bar OS - Alky injection tuning
Moderately Differentiated
so for hpt.....zero out the pe table? So it will pick the BE table....hmmm.
****EDIT****redundant? what if you are OL and up in rpm but not map? At 100kpa 3500 rpm I'd like a little richer scenario than 14.7. This is easily accomplished with a working PE table. Tip into boost and let BE handle it. Seems on the street, even with the radix I can get some rpm's but no boost or very little. Seems pe is only redundant if you are in boost.
Hello Dave
Or use PE as an intermediate fueling, to handle something like 90-110kPa. Rather than use PE for your final fueling, have it command something like you would see on a n/a setup. 13:1 up to 110kPa, then BE to richen up a tad more before leaning back out to account for meth.
That's howI use mine, PE 85 to 105kpa, PE actually RPM based, but I have BE to not kick in until 110kpa. I guess that'd work fine, if you are lucky enough that incorporating your alky gives you a BE target richer than your PE in those same rpm regions.
Just keep the PE target at 13.5 to 13.6 and you should be fine if like you said 13.2 is your finally adjustment on the BE. 13.2 is richer than 13.5.
Hello Dave
Oh, and for the record, your avatar scares me.
I AM A MOTHERF*CKER
*IF* you are using a 2+ bar SD tune. I just read the bit about HPT only giving you one row in that table... That really isn't a multi-bar tune -- that's a 1 bar tune with a boost ref'd (instead of rpm) PE table.
But, the principle still holds -- if you use the BE Table, then the PE table is redundant (or vice versa). K.I.S.S. principle in action -- make your boost fueling decisions in one place, and make them easy to tune.
I haven't had a PE table turned on for years. Basically I do all my fueling calcs from the VE table (which for EFI custom OS is two full range VE tables -- one for vacuum to atmospheric, and one from atmospheric to 3 bar).
Hello Dave
Given that I'm not using meth though, that would alter things a bit, as I assume you don't have to be as rich.
I AM A MOTHERF*CKER
That's true. I also slowly ramp up in the commanded fuel table prior to hitting 105kpa, so that it isn't a big shock to jump to 11.5:1. Essentially that's what you are doing with the PE (if I'm understanding you correctly) and then buffering for fuel shortage (which I do with meth )
Hello Dave
