2bar OS - Alky injection tuning
#33
How do I change this text
Originally Posted by KySilverado
Are we talking street tunes vs track tunes when we are turning off PE. I don't see turning off my PE on the street. I can and have gone to 6000 rpm without going into boost while tuning VE. I don't want to be at 14.7 AFR there.
#34
I AM A MOTHERF*CKER
You can still handle this in the VE table and Commanded Fuel x RPM. Does HPT keep you from this somehow?
#35
Moderately Differentiated
#36
I AM A MOTHERF*CKER
Originally Posted by dewmanshu
yeah, that table justin posted up is what you are talking about right? the commanded fuel x rpm? yeah we don't have one of those. nowhere that i know of can we command an afr at any rpm/kpa. The open loop table is only temp based. PE multiplier is only rpm based. and BE multiplier is only kpa based. we have the ve table as a base and then the multiplier tables (only an x-axis)
AHHH!!! Now I understand.
In that case, PE may not be redundant for HPT
#37
I think the answer is to tune my VE table in boost regions for meth unless I can run PE Enrich leaner than Boost Erich + Meth which I doubt.
I have put a request in to HPT for a Boost Enrich vs rpm vs map table. Doubt it will happen but no harm requesting.
#38
Hello Dave
#40
