3k stall in, now constant lock/unlock of TCC
Old 05-16-2010, 08:16 AM
  #21
RedHot04's Avatar
If you have tow/haul turn it on and see how that feels... It keeps mine from lugging at low speeds. just a thought, until you get it tuned..
Old 05-16-2010, 04:19 PM
  #22
phasemaster1's Avatar
I had the same problem could not fix with tuning. Ended up being garbage converter found out when clutch material clogged and took out my transmission pump.
Old 05-16-2010, 04:54 PM
  #23
99LsSilverado's Avatar
Well I dont think it would be clutch material because the converter is new and the trans was rebuilt with corvette servo and a shift kit. I tried the tow/haul and it does not help it.
Old 05-16-2010, 07:34 PM
  #24
MikeGyver's Avatar
i should have started a new thread, you guys all have a set point problem and mine is a throttle position problem.
Old 05-16-2010, 07:56 PM
  #25
Mine was also brand new. Used a cheap converter, what brand is yours?
Old 05-16-2010, 08:47 PM
  #26
my converter is a 3000 stall by Circle-D
Old 05-16-2010, 08:57 PM
  #27
Circle-D is good. Getting any codes?
Old 05-16-2010, 09:21 PM
  #28
no code are coming up but like i said i would like to move the tcc lockup to about 45 mph till i get my tune and then go from there
wickedRCSB
10-30-2015 09:45 PM
Miguel199
10-16-2015 08:04 PM
Wolftrk99
10-02-2015 08:17 AM
bisqikss
09-27-2015 09:40 PM
sTNT971
09-26-2015 06:27 AM
Quick Reply: 3k stall in, now constant lock/unlock of TCC
