4.8 wont start!! PLEASE HELP.
Old 02-22-2012 | 07:17 PM
  #21
thunder550's Avatar
High on diesel fumes
Pull out the relay and jumper pins 30 and 87 together with a paperclip or something. Should start the pump running.
Old 02-22-2012 | 07:20 PM
  #22
Benjaminsince90's Avatar
what sre jumper pins.. and do i stivk wires in those holes??? should i have the key on?
  #23
i meant to say are*
Old 02-22-2012 | 07:22 PM
  #24
thunder550's Avatar
Key on doesn't matter. If you look at the bottom of the relay you should see 4 pins labeled 30, 85, 86, and 87. Find the corresponding holes for 30 and 87 and put a wire in those two holes to connect them together. That should get the pump running .
If you want some help let me know, I'm sitting on my *** at home watching TV, wife is gone right now and helping a friend with taxes later, so I'm in for a boring evening
Old 02-22-2012 | 07:53 PM
  #25
1dirtybird's Avatar
That is a mighty nice offer Thunder.
Id do the same if you were on the tempe/south scottsdale end
Old 02-22-2012 | 08:15 PM
  #26
thanks man i appreciate it but i figured it out and drained her dry!!.. now all i gatta do is put more gas into it and go from there... either today or 2marro... now if thats not the case. can a fuel filter cause it not to run? again thanks for the offer!!
Old 02-22-2012 | 09:09 PM
  #27
could it be the intake gaskets? i used the same ones they looked fine. but my pops has it in his mind that its the gaskets and Ive read that people have no problem reusing them.
Old 02-22-2012 | 09:12 PM
  #28
thunder550's Avatar
No prob, glad you got it drained. I'm not sure how that treatment stuff affects the fuel filter, start with the fresh gas and go from there. The intake manifold gaskets won't change anything, if it'll run spraying gas in the intake that's not the problem. They are designed to be reusable.
Old 02-22-2012 | 09:34 PM
  #29
ok thanks plus they are green instead of red and im thinking the guy that own it before me replaced them and they looked pretty damn new. ohh and wheres the best place to get synthetic oil? for cheap? i want to use royal purple but that's just too expensive.
Old 02-22-2012 | 09:45 PM
  #30
1dirtybird's Avatar
Napa has their's on sale for 3.49 a qt I use it in all my stuff get their gold filter its still the long style
The green gaskets are updated from the orange, way better.
put some gas in there and cycle the pump a few times then crank it shoud start quickly. If the pump is weak it wont start, you should have enough flow thorugh the filter to at least idle.
