4L80E 4-2 downshift??
Old 02-21-2013, 01:01 AM
11 Second Hall Moniter
AKlowriderZ71's Avatar
Default 4L80E 4-2 downshift??
I need a little help here guys. Recently helped a friend swap his 60E for an 80E, did the segment swap, and adjusted his tune for shift points & firmness, etc. But the transmission does one thing that he does not like.
If it's in 4th gear with the converter locked, and gets on the throttle aggressively or goes WOT, it unlocks the converter, then shifts to 3rd, then a second later shifts into 2nd gear. It doesn't seem to matter what I change, I can't seem to make this thing go straight to 2nd gear from 4th.
Is this just the way it is?
Old 02-21-2013, 01:49 AM
gamble686's Avatar
Sounds like an issue with the shift tables. What changes from stock did you make? Did you only adjust WOT shift speeds/RPMs or the partial as well? Also have you logged the truck while doing this? What does the TPS% look like during these shifts? Is this a DBC or DBW truck? Also what does your TPS enable full throttle % look like? Something seems very odd here.
Old 02-21-2013, 03:07 AM
oakley6575's Avatar
Definitely not the way it should be. Have you logged the truck when it happens. I'm sure you can log commanded gear and see if it commands third then second.
Old 02-21-2013, 03:25 AM
Mod with training wheels
smokeshow's Avatar
When driving in OD, it has to logically command 3rd and then sample the TPS, RPM and VSS in order to determine if it can and still needs to downshift. Whether or not the transmission responds promptly is all in the transmission... Fluid circuits react a little slower than electrical circuits
The 6 speed is designed to skip gears though. Rowing down through all those gears would be cumbersome. I haven't seen any 6 speed tune files that have the parameter that controls it, but I assume the TCM uses some minimum load transient that enables the transmission to skip gears to get the vehicle up and moving quicker. Obviously the 80e is too simple for that, nor is it really necessary with only 4 gears.
Old 02-21-2013, 04:48 AM
11 sec. Truck Mod
TIM Z's Avatar
My stock 80e in my van does this Roger .
Have him manually drop it into 3rd /D when he's gonna mash it if it bothers him.
I do this in all my vehicles , the 60 has me "downshift paranoid " lol
Old 02-21-2013, 09:10 AM
KHester84's Avatar
I thought the 6 speeds design made it necessary for each gear to be "clutched" until the right gear is selected, where as the 4 speeds can jump to any gear they want. If you punch it in 6th, you'll feel it shift to 5th, then 4th every time...maybe it can be tuned out tho
Old 02-21-2013, 09:20 AM
smokeshow's Avatar
No, there are skip shift settings in the tune for the A6. It's meant to jump around.
Old 02-21-2013, 09:46 AM
chevrolet all the way's Avatar
What jake said! its supposed to do that. the trans may be a little lazy causing it to be drug out, but thats what they do. i almost always downshift using my tow haul button (setup in tune) before i do a wot pull considering a downshift is a very harsh action when making good power.
Old 02-21-2013, 09:49 AM
nonnieselman's Avatar
i cant feel mine dropping to third then 2nd.. but it sure does take a long time to go from 4 to 2..
So i setup my tow haul button to go to the lowest gear possible just for whatever reason.
>47 and it drops to 1st
>85 and drops to 2nd
No waiting and it hits hard.
Old 02-21-2013, 11:15 AM
Thats what i did nonnie. also good for brake boosting
Quick Reply: 4L80E 4-2 downshift??
