4L80E 4-2 downshift??
Alright guys, thanks for confirming what I already suspected.
The transmission is fresh & has a shift kit. It downshifts quickly & firm. He is just used to his old 60E, and the way this one acts was different and he was alarmed. Asked me if I could change it. I didn't want to be wrong when I told him it was normal.
Sounds like an issue with the shift tables. What changes from stock did you make?
Lots of changes, trans is built & has shift kit and a Pro Yank.
Did you only adjust WOT shift speeds/RPMs or the partial as well?
I made several adjustments to all of the tables, and it still acted the same.
Also have you logged the truck while doing this? What does the TPS% look like during these shifts?
Yes, the datalog shows the PCM commanding the shifts in this manner. TPS at 100%.
Is this a DBC or DBW truck? Also what does your TPS enable full throttle % look like?
It's an early DBC (GMC C3). Full throttle enable at 85%. Tried lowering it just for ***** & giggles, didn't change anything.
Something seems very odd here.
Looks like it's normal actually.
I didn't want to ignore your post, so I answered your questions above, in red.
Why don't you datalog yours, and see if the trans commands 3rd before it commands second, and report back?
