4l80e guys, please step in
I have a gauge for that
When I am tuning part throttle shift points I keep in mind what gear I am in, and if I dont like a shift point I look at the speedo and see what speed it shifts then go into the trans table and turn that down a bit....kind of cumbersome but works really well.
That's kind of what I did for normal driving and WOT. It worked ok for the 22's but I still have to work on the slick setup. Changing from a 31.5" to a 27" changes a lot. I thought I had it dialed in but it was hanging up a little on the 1-2 but a lot on the 2-3.
12 Second Club
Give this one a shot if you like. This is a friend of mine's 80e. I recalculated the tire and gear for ya and scaled the trans tables for 4.56 and 27" tires. You can try these if you like. As far as I've ever known the transgo shift kits need stock shift pressures and shift times to work correctly. But see how you like these shift speed tables.
