4L80E swap, now transmission codes.
Adkoonerstrator
Ok, so the 4L60E to 4L80E swap is done and the truck is running. I got my EFILive .tun file in last night. It was for a 2001 6.0L/4L80E combo. I changed the engine size, fuel injectors, tire size, gear, and some other little stuff. I didn't mess with any transmission settings in the file.
I started the truck up and it runs fine with the new tune except it's throwing 4 codes for the transmission and has one other pending. Here they are
P0748 Pressure Control Solenoid A Control Circuit(Pending)
P0753 Shift Solenoid A Control Circuit
P0758 Shift Solenoid B Control Circuit
P1638 Generator F Terminal Circuit
P1860 Torque Converter Clutch Pulse Width Modulation Solenoid
Anyone have any idea what is wrong? I have both VSS sensors hooked up. Does it matter which one goes where? The adapter that rearranges the outputs of the big plug on the back of the transmission is hooked up also. There are no transmission leaks and the fluid is full.
I haven't driven the truck yet but, have put it in gear while up on jackstands and it turns the tires over like it should. I don't want to drive it with those codes because something must not be exactly right.
Help.
Help.
Adkoonerstrator
Ok, I noticed that P1638 is for the alternator terminal. I guess with the 2001 tune file I used you need to have some extra wire from the alternator. I know I've seen that info here before so I'll search for it.
Could that code be causing the other transmission codes to pop up? Most of the transmission codes say they can be caused by a high or low voltage condition, just wishful thinking on my part probably.
It looks like some type of voltage problem. Check fuses, probably will be the problem.
Here is a trouble shooting chart for the p0753 code
Circuit Description
The 1-2 shift solenoid (SS) valve controls the fluid flow action on the 1-2 and the 3-4 shift valves. The 1-2 SS valve is a normally-open exhaust valve that is used with the 2-3 SS valve to allow for four different shifting combinations. The 1-2 SS valve attaches to the control valve body within the transmission. The ignition voltage goes directly to the 1-2 SS valve. The PCM controls the 1-2 SS valve by providing the ground path through the 1-2 shift solenoid valve control circuit.
When the powertrain control module (PCM) detects a continuous open or short in the 1-2 SS valve circuit or the 1-2 SS valve, then DTC P0753 sets. DTC P0753 is a type C DTC. For California emissions vehicles and vehicles under 8600 GVW, DTC P0753 is a type A DTC.
Conditions for Running the DTC
• The system voltage is 8.0-18.0 volts.
• The engine runs more than 400 RPM for greater than 7 seconds.
Conditions for Setting the DTC
All conditions for running the DTC are met, and either of the following conditions occur for 4.3 out of 5 seconds.
• The PCM commands the solenoid on, and the voltage input remains high (B+).
• The PCM commands the solenoid off and the voltage input remains low.
Action Taken When the DTC Sets
• For California emission equipped vehicles, the PCM illuminates the malfunction indicator lamp (MIL) during the second consecutive trip in which the Conditions for Setting the DTC are met. For Non-California emission equipped vehicles, the MIL is not illuminated.
• The PCM commands maximum line pressure.
• The PCM freezes shift adapts.
• The PCM inhibits 3-2 downshifts above 40 km/h (25 mph).
• The PCM records the operating conditions when the Conditions for Setting the DTC are met. The PCM stores this information as Freeze Frame (Calif. only) and Failure Records (Calif. and Federal).
• The PCM stores the DTC P0753 in PCM history during the second consecutive trip (Calif.) or the first trip (Federal) in which the Conditions for Setting the DTC are met.
Conditions for Clearing the MIL/DTC
For California emissions, the PCM turns OFF the MIL during the third consecutive trip in which the diagnostic test runs and passes.
A scan tool can clear the MIL/DTC.
For California emissions, the PCM clears the DTC from PCM history if the vehicle completes 40 warm-up cycles without an emission related diagnostic fault occurring.
For Federal emissions, the PCM clears the DTC from PCM history if the vehicle completes 40 warm-up cycles without a non-emission related diagnostic fault occurring.
The PCM cancels the DTC default actions when the fault no longer exists and the ignition switch is OFF long enough in order to power down the PCM.
Diagnostic Aids
• An open ignition feed on the Off/Run/Crank voltage circuit (CKT 1020) can cause multiple DTCs to set. Refer to Shift Solenoid Valve State and Gear Ratio .
• DTC P0753 defaults to an elevated line pressure condition which may result in TCC partial apply. This may induce idle surge and engine stall.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
This step tests the function of the 1-2 SS valve and the internal wiring harness.
This step tests the power to the 1-2 SS valve from the ignition through the fuse.
This step tests the ability of the PCM and the wiring to control the ground circuit.
This step measures the resistance of the automatic transmission wiring harness assembly and the 1-2 SS valve.
DTC P0753 Step
Action
Value(s)
Yes
No
Did you perform the Powertrain Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - Engine Controls (6.0 L) or Diagnostic System Check - Engine Controls (8.1 L) in Engine Controls
Install a Scan Tool .
Turn ON the ignition, with the engine OFF.
Important: Before clearing the DTCs, use the scan tool in order to record the Freeze Frame and Failure Records. Using the Clear Info function erases the Freeze Frame and Failure Records from the PCM.
Record the Freeze Frame and Failure Records.
Clear the DTCs.
Were DTCs P0753, P0758, or P1860 also set?
Go to Step 3
Go to Step 4
Inspect the transmission fuse.
If you find an open fuse, inspect the following components for a short to ground:
- Off/Run/Crank voltage circuit (CKT 1020)
- The 1-2 shift solenoid
- The 2-3 shift solenoid
- The TCC PWM solenoid
- The automatic transmission wiring harness assembly
Repair the circuit, the solenoid, and replace the harness if necessary.
Refer to Wiring Repairs in Wiring Systems or to Wiring Harness Replacement.
Did you find and correct the condition?
Go to Step 17
Go to Step 4
Using the transmission output control function on the scan tool, command the 1-2 SS valve ON and OFF three times while listening to the bottom of the transmission pan. Use a stethoscope if needed.
Does the solenoid click when commanded?
Go to Intermittent Conditions in Engine Controls
Go to Step 5
Turn OFF the ignition.
Disconnect the transmission 20-way connector. Additional DTCs will set.
Install the J 44152 jumper harness (20 pins) on the engine harness connector.
Connect a 12 volt test lamp from the J 44152 cavity E to ground.
Does the test lamp illuminate?
Go to Step 7
Go to Step 6
Repair the open or high resistance in the Off/Run/Crank voltage circuit (CKT 1020) to the 1-2 SS valve.
Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 17
Install a 12 volt test lamp between cavities E and A of the J 44152 .
Using the transmission output control function, command the 1-2 SS valve ON and OFF three times.
Does the test lamp illuminate when you command the shift solenoid ON and turn off when you command the shift solenoid OFF?
Go to Step 10
Go to Step 8
Test the 1-2 shift solenoid valve control circuit (CKT 1222) of the 1-2 SS valve for an open or short to ground.
Go to Step 17
Go to Step 9
Replace the PCM.
Refer to Powertrain Control Module (PCM) Replacement (6.0 L) or Powertrain Control Module (PCM) Replacement (8.1 L) in Engine Controls.
Did you complete the replacement?
Go to Step 17
Install J 44152 on the transmission 20-way connector (Automatic Transmission Connector End View).
With the J 39200 digital multimeter (DMM) and the J 35616 connector test adapter kit , measure the resistance between terminals A and E.
Does the resistance measure within the specified values?
19-31 ohms
Go to Step 12
Go to Step 11
11
Disconnect the automatic transmission wiring harness assembly from the 1-2 SS valve.
Measure the resistance of the 1-2 SS valve.
19-31 ohms
Go to Step 15
Go to Step 16
Measure the resistance between terminal A and ground. Use the J 39200 DMM.
Does the resistance measure greater than the specified value?
250 K ohms
Go to Step 14
Go to Step 13
13
Measure the resistance from the component's terminals to ground.
Do both readings measure greater than the specified value?
250 K ohms
Go to Step 15
Go to Step 16
14
Measure the resistance between terminal A and all other terminals, except terminals B, E, and S of the J 44152 .
Refer to Automatic Transmission Inline Harness Connector End View .
Is the resistance between terminal A and any other terminal, except terminals B, E, and S less than the specified value?
Go to Step 15
Replace the automatic transmission wiring harness assembly.
Refer to Wiring Harness Replacement.
Go to Step 17
16
Replace the 1-2 SS valve.
Refer to Control Valve Body Replacement .
Go to Step 17
17
Perform the following procedure in order to verify the repair:
Select DTC.
Select Clear Info.
Select the parameters 1-2 Solenoid and 1-2 Solenoid Open/Short to GND, and 1-2 Solenoid Short to Volts.
Operate the vehicle under the following conditions:
- The PCM commands the 1-2 SS valve ON, and the 1-2 Solenoid Short to Volts is NO.
- The PCM commands the 1-2 SS valve OFF, and the 1-2 Solenoid Open/Short to GND is NO.
- All conditions met for 5 seconds.
Select Specific DTC.
Enter DTC P0753.
Has the test run and passed?
System OK
Go to Step 1
Document ID# 654947
2001 Chevrolet Chevy C Silverado - 2WD
Circuit Description
Diagnostic Aids
Test Description
DTC P0753 Step
Action
Value(s)
Yes
No
Go to Step 2
Clear the DTCs.
Go to Step 3
Go to Step 4
Go to Step 17
Go to Step 4
Go to Step 5
Go to Step 7
Go to Step 6
Go to Step 17
Go to Step 10
Go to Step 8
Go to Step 17
Go to Step 9
Replace the PCM.
Go to Step 17
19-31 ohms
Go to Step 12
Go to Step 11
11
19-31 ohms
Go to Step 15
Go to Step 16
250 K ohms
Go to Step 14
Go to Step 13
13
250 K ohms
Go to Step 15
Go to Step 16
14
Go to Step 15
Go to Step 17
16
Go to Step 17
17
Select DTC.
Select Clear Info.
Enter DTC P0753.
System OK
Go to Step 1
Document ID# 654947
High on diesel fumes
99 and 00 trucks used a 1-wire alternator, 01 and up use a 2-wire alternator. If I remember correctly, the 99-00 alternators were internally regulated, meaning that they were always charging. On the 01 and up alts, they are externally regulated, meaning that the computer controls when the alt turns on and off and the output voltage, hence the need for the extra wire. A newer truck can use an older alt, but will throw codes and light up the battery light, which will get f-ing annoying. An older truck cannot use a newer alt though, the alt will never turn on. The code will not hurt anything, but that damn battery light will get annoying flashing all the time. I had Bryan at PCMFORLESS turn off my battery light when I put in my internally regulated alt. The code still shows up, but it doesn't hurt anything.
Adkoonerstrator
Thanks Ranwalk
I have the service manual here with that info, just seeing if anyone has ran into this before.
I'll check out my fuses here in a bit.
Adkoonerstrator
Thunder550 - If that alternator code is no big deal I can turn off the light with my EFILive Flashscan setup. I wondered what that damn thing was flashing for.
LS1Tech Sponsor
There are three wires you need to put in different pins on the grey plug that goes into the trans. They are different from the 4l60 to the 4l80. All you do is pull the harness end apart, and Just put the pins into the right pin.
And on the l terminal code, Just delete it and you will be fine.
I can get you the exact pinout if you need it, Jes
Adkoonerstrator
Hey Jes
I got an adapter that is supposed to swap the wires around on the grey plug. Maybe it is not right and is causing the problem.
If you can get me the pinout that would be great. I can take the harness off and check to make sure the pins are swapped like they need to be with a multimeter.
Thanks guys.
Thanks guys.
