60lb injectors on stock tune
i would but i allready soldered in ls1 injector clips. i know the 80e wont work with the 60e tune, but at least the trans would fill the tc and cooler with fluid wouldnt it?
Former Vendor
Use the Camaro injectors as they are only about 3 lbs bigger and since you are already using the EV1(LS1) connector it will be as simple as popping them in. Maybe someone on the LS site can hook you up with a set and mail them to you or better yet maybe someone local that can meet you.
You should have used Whippled's Multech to EV1 adapter harness.
Dewy was going to buy a set but decided to buy trany fluid instead....see what that got him?
Just swap'em back to stock....do dont take a chance with it!!
5.3lSilverado
25
08-29-2016 12:48 AM
mzoomora
01-03-2016 07:06 AM
Mossyoakglock
07-17-2015 08:30 AM
