87 vs. 93
Old 10-12-2009, 12:01 AM
  #21
AJII's Avatar
My highway mileage SUCKS compared to yours. Took it on a ~300 mile round trip this weekend and netted 15.5 mpg
Old 10-12-2009, 09:34 AM
  #22
dlt76028's Avatar
Originally Posted by RandomHero
I have mine setup to lock in 3rd gear at 38 mph and my 4th setup to lock at 48. It's great because around town I just put it in "3" and on the highway I keep it in 4th "D." I pull 12-14 in town with an ss3600 converter and 21-22 on the highway.
why would you not take advantage of your 4th gear around town? thats alot of extra rpms driving around.
Old 10-12-2009, 11:55 AM
  #23
RandomHero's Avatar
Gas mileage isn't rpm specific. That is a good part of it, but engine load is more important. Don't believe me? Go put your truck in 4th gear with the converter locked and push the pedal down as far as you can without downshifting and see what kind of gas mileage you get. Then put it in 3rd with it locked and compare the gas mileage.
I've logged gas mileage with both EFI Live and my Aeroforce scan gauge. The truck has to use much more fuel with a higher load on it.
On a cable driven throttle body(I can't speak for an electronic one), the amount of air that enters the engine relies on your right foot. Even though the truck hasn't downshifted there is more air entering the engine. The PCM has one of two choices: To maintain the same fuel level and go lean, or to increase fuel to compensate for the added amount of air.
It's the same reason why people see an increase with lower gearing. There is less stress on the engine and less effort to get it moving.
Now obviously we aren't all rolling around with 5.13 gears so there is a point where rpm plays a larger factor than engine load.
Old 10-12-2009, 12:03 PM
  #24
Wearin' da big hat
00ChevyScott's Avatar
My truck drives around at 40 mph in 4th gear, converter locked just fine. I don't have to give it much gas because I'm usually holding speed and barely even have to crack open the throttle body to hold a constant speed. I actually hate 3rd gear lock up. I have it set not to lock up at all until 4th gear.
Old 10-12-2009, 12:26 PM
  #25
dlt76028's Avatar
mine locks in fourth and i barely have to give it any gas to hold 45mph, in fact i let off the gas a lot so i don't speed. and my tune is setup to run lean while cruising. i get 18mpg every tank with 50/50 mixed...
Old 10-12-2009, 12:27 PM
  #26
Wearin' da big hat
I've never calculated my MPG and never will. **** that, I know it's bad
Old 10-12-2009, 12:33 PM
  #27
2nd fastest 5.3 ECSB
trever1t's Avatar
Mark is correct I watch manifold pressure when cruising
Old 10-14-2009, 02:54 AM
  #28
Cammed4ever's Avatar
Might be a dumb question but, how do you know or what do you feel when your verter locks up or unlocks??
Old 10-14-2009, 08:22 AM
  #29
trever1t's Avatar
it feels like another gear, your rpms will drop ~300. Tapping the brake will cause it to unlock. Test it.
Old 10-14-2009, 05:34 PM
  #30
So when the rpm's drop the verter will be locked or unlocked?
Thanks man!
Quick Reply: 87 vs. 93
