ABS Light and Parking Brake Light
Good luck with it.
The dealer might be able to do a "reset" on it too. When I had my 00 ECSB GMC still under warranty the lights came on a couple of times. The first time they cleaned the front wheel sensors and the second they did something to reset the module. Can't recall exactly what they did but they used a Tech II.
My Brothers 2001 Silverado had the same symptoms and it ended up being the ebcm or whatever the module is called. It's not a cheap part so hope it's something a little more simple than that
What gets me is that I unbolted the exhaust before and it did it so I bolted the exhaust back up and it took alittle driving but it went back to normal so I know that the sawsall had nothing to do with it. Little **** like that annoys the crap out of me because it happens just out of no where.
could be a bad ground too, my buddies was doing that same thing after him and his buddies did a v6 to v8 swap, brought it over to me and i found that the main ground that goes from the cylinder head to the cabs fire wall was not connected, fixed that and all the issues were gone including the dim brake lamps...?
Not necessarily. I have the same problem. My parking brake and abs lights both come on and go off randomly. But everything works fine. I can go down the road and hit a bump and theyll come on and may stay on or may go off. Ive checked everythkng. Its like a short i cant find. Not saying my cause is the same cause i didnt sawzall anything. But somethings going on.
AND i happen to have a spare from a wrecked truck ill make you a killer deal on since you need it. PM me if you are interested.
