AC blows cold, then hot
its been doing it since i bought the truck back in '07 but then it was much more sporadic. you turn the truck on with the AC on and about the time the coolant temp is at full temp the climate control unit goes to full heat. moving the temp control sliders does nothing. the only way to get it to cool again is to shut the truck down. it happens much more often now than it used to. other than that stupid fault the ac seems to work just fine. anybody experienced this before and know what it is?
Mine would do that when not moving when fans werent working... might want to check on those to make sure theyre moving a good cfm, that could be an issue.
Does it only happen at a stop at operating temp or does it even blow hot when moving?
it's manual dual climate control with the 2 sliders but they don't have to be adjusted for the effect. it just does and when it does the sliders do nothing; it's at full heat from all vents. this happens under the same condition every time: minutes after initial start-up (cold or hot) but only once the truck has reached operating temp. until then it blows cold. if the truck is already warm it begins seconds after start-up but still after blowing cold. its not the compressor because it only does this some of the time and cools fine at a stop or driving when working like it should. but when it's acting up it's not just not cooling: it's blowing FULL HEAT... like the burn the hair off your knuckles kind of hot. seems to me to be a control issue instead of mechanical one for these reasons and that it only requires the truck to be shut down for seconds before restarting for it to work normally again.
lukn4trbl355
10-22-2015 12:19 AM
Wrecker 426
09-30-2015 10:39 PM
Closer_2001
09-24-2015 10:15 PM
