AEM UEGO Broke?
Old 09-27-2010 | 07:23 PM
viciousknid's Avatar
Where's the Beef?
Default AEM UEGO Broke?
Problem: Wideband GAUGE says 13:1 AFR while EFI PID says 15:1 AFR.
A: Gauge took a **** and I need a new one? The plugs on the back get really hot and actually melted the housing a tad.
B: I need a better power/Ground connection? Have it plugged in to Cig Lighter for easy vehicle to vehicle usage.
C: All of the above.
Old 09-27-2010 | 07:29 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Could be any of those I guess. Could also be....
D: Sensor needs replaced.
Old 09-27-2010 | 07:33 PM
Where's the Beef?
Why would the sensor cause the gauge to put out 2 separate AFR's? I have 2 sensors so I can try them both to see.
Old 09-27-2010 | 07:41 PM
I see your point, I didn't think about that. I had an AEM sensor go bad last year. Any time I tipped into the throttle, it read 10.0 no matter what.
I'd probably try the better power & ground connections first, but they are the same power & ground that the sensor is using. So, it might just be the gauge. Try to borrow somebody's gauge, plug it in & see if it reads correctly then.
Old 09-27-2010 | 07:53 PM
Where's the Beef?
no one around here has one except the dyno shop and I doubt he'll let me borrow it.
I'm looking to buy a used one later this week I think.
I'm gonna try a better power source and see where we sit.
Old 09-27-2010 | 09:28 PM
charcold-bowtie's Avatar
Has it always read the same?
my PLX is off a hair from what the computer shows, its just cause the external voltage loses etc.
Old 09-27-2010 | 09:37 PM
Where's the Beef?
it used to be off just a touch. lik .2-.4
Old 10-07-2010 | 07:48 PM
Where's the Beef?
Got a new wideband and found the prob. Power wires going into the wideband weren't getting a good connection. I'll repin it later and have 2 good widebands
Texas5.3_1251
03-05-2016 09:10 PM
FlyingLow
11-24-2015 11:05 AM
lukn4trbl355
10-22-2015 12:19 AM
Velocity1
10-02-2015 09:01 AM
Wrecker 426
09-30-2015 10:39 PM
