AEM uego wideband is PISSIN ME OFF
Old 05-02-2013 | 03:52 PM
oneBADDz's Avatar
Originally Posted by slowswb
why dont you just change to sensor and see if that fixes it.
Originally Posted by WhiteX
Alright,
So I picked up a used AEM UEGO wideband from a good buddy for cheap as hell. I know FOR SURE it worked in his Grand National because I helped him wire it up. He sold the GN and the part sat forever. It was used for maybe a month.
I decided it would be a cheap investment to put it onto my truck and got a bung welded in directly after the header collector. Installed everything and started the truck up. It appears to work for a few seconds then goes full lean.
New sensor, damn, so not that great of a deal. Get the new sensor in and install and THE SAME **** HAPPENED! Ahhh so mad.
So it must be a wiring issue. I did a continuity test on all the wires and they all checked out. I changed the power wire so it's wired directly to the battery and still nothing.
Anyone have any great input? I've Googled the **** out of the issue and haven't come across anyone who has gone as far as doing a continuity test to test the wiring. Some people have changed sensors with success and others have still had issues.
Old 05-02-2013 | 07:02 PM
yzriders182's Avatar
I have one brand new out of the box doing the same dam thing!!! just got an innovate Lm2 to make sure its not an exhaust leak or something then I will be contacting AEM...
So far this unit seems like a big steamy pile of turd...
Old 05-03-2013 | 02:07 PM
WhiteX's Avatar
Originally Posted by oneBADDz
Have you contacted AEM? In my experience they are pretty helpful. Did you mount the sensor in the orientation that the instructions say to? I wouldn't imagine that's the problem though, especially with a new sensor having been tried as well.
You don't have to calibrate the AEM setups.
Maybe in the long period of time that it sat around it got banged up for something and is actually damaged?
Have you driven with it to see if it ever comes back into range or is this only being checked at idle?
Yeah I've driven for a few hours without it changing.
I did everything to spec with the instructions. The sensor is at about a 40 degree angle .
Old 05-03-2013 | 02:08 PM
WhiteX's Avatar
Originally Posted by subeone
you have it grounded properly? check if the sensor gets hot when power is applied. AEM wideband comes pre calibrated
I have not checked for it getting hot and to be honest I didn't check the ground I dont think. Good call brother.
Old 05-03-2013 | 04:17 PM
tiffo60's Avatar
The ground is the most important part of the functionality of a wideband in my experience
Old 05-03-2013 | 06:57 PM
Area47's Avatar
how about going through the calibration procedure listed in the instructions, and yes there is a calibration procedure.
Old 05-06-2013 | 11:28 AM
WhiteX's Avatar
I hooked the power and ground directly to the battery and it went full lean within about 10 seconds. For those 10 seconds I was pretty happy. Oh well
Area47,
I went through this:
http://www.schnitzracing.com/manuals/AEMWBK.pdf
Only thing I found was something with the screw on the back. I will mess with that?
oneBADDz's Avatar
No there isn't. The instructions list calibration changes for their standalone system and you can calibrate outputs and whatnot, but there is no calibration for the function of the wideband and gauge.
Each AEM UEGO sensor is individually calibrated and a resistor integral at the connector body is laser trimmed with this value. This process replaces the traditional “free air” calibration procedure when changing sensors and implements a sensor specific calibration for unparalleled accuracy.
http://www.aemelectronics.com/Images...%2030-4100.pdf
Maybe I'm missing something?
Old 05-06-2013 | 11:36 AM
Area47's Avatar
in the instructions when i put in my aem uego, it stated upon first key cycle leave the sensor out of the exhaust to calibrate the heater and such things. im just going off what i did with mine and what the instructions stated. it's not an uncommon deal to have a bad gauge setup either.
Old 05-06-2013 | 12:29 PM
WhiteX's Avatar
I appreciate it regardless as I am out of options. Ill try that just for ***** and giggles.
SS94S10
01-03-2019 02:57 PM
Texas5.3_1251
03-05-2016 09:10 PM
FlyingLow
11-24-2015 11:05 AM
97_ek
09-23-2015 10:16 PM
madmann26
09-06-2015 05:19 PM
