Aeroforce Interceptor Scan Gauge oddity...
#21
I have had two sets of these Gauges and both started having connection problems. When the first set started giving me problems I noticed the pins seemed loose on the OBDII connector. I split the connector open and found cold solder joints, re-soldered all the pins and the problem was resolved. Same thing when the newer set started acting funny.
I unplugged and plugged mine in a lot with all the flashes and scans and figured that could have caused the solder connections to crack.
If they start acting up again try re-solder the connections first.
dantheman1540
02-24-2016 09:56 PM
zblee
09-17-2015 07:58 AM
