Air Fuel Ratio Lambda 93 E85 info
Old 07-31-2014 | 01:06 PM
  #21
Vortec350ss's Avatar
So many questions... we need a fuel expert to chime in here lol
Old 07-31-2014 | 02:10 PM
  #22
Chevy_King1500's Avatar
its not that serious, you will need a dyno to measure any changes
Old 07-31-2014 | 03:40 PM
  #23
slowec's Avatar
Back road, cordless drill, hack saw blade , and a few sets of spark plugs.
Old 07-31-2014 | 03:59 PM
  #24
oakley6575's Avatar
Yea plug reading is your best option when mixing fuels but how serious do you guys want to get.
So many questions..
Like what? Atomic and Smokeshow seem pretty fluent with boost, fuel, and tuning so maybe they will chime in soon. I know smokeshow runs a ethanol blend in his truck and atomic runs a lot of meth.
I'm sure they are both watching this thread waiting for someone to say something stupid or something they don't agree with.
Old 07-31-2014 | 06:29 PM
  #25
smokeshow's Avatar
Mod with training wheels
How did you know?
To answer the question about adjusting your actual lambda with different fuels, see here:
FUELS DATA
Air / Fuel Ratios for a Wideband Oxygen Sensor - Hot Rod Magazine
The only thing complicating it is calculating the amount of methanol you're injecting when the PCM isn't aware of the additional fuel. When you inject enough methanol that you have to reduce fueling in the tune, you can use that reduction value to figure the amount injected by your meth kit. Then calculate the percentage of methanol you're running and adjust target lambda as necessary.
Old 07-31-2014 | 06:37 PM
  #26
oakley6575's Avatar
Yep Yep Yep
Old 07-31-2014 | 07:46 PM
  #27
timmay208's Avatar
correct me if im wrong but 1.0 lambda is 14.68. I read lambda on HPT scanner but my wideband still is reading AFR
my truck cruises around .99-1.01 lamba via my scanner and on my wideband in afr is like 14.4-15.2 or so
Old 07-31-2014 | 08:06 PM
  #28
GMCtrk's Avatar
The AFR for stoich (lambda 1) depends on the type of fuel. Stoich on e85 is 9.76 and I shoot for 7.1:1 at WOT.
Old 07-31-2014 | 08:59 PM
  #29
oakley6575's Avatar
Yes on the gas scale
Old 08-01-2014 | 10:25 AM
  #30
Originally Posted by smokeshow
How did you know?
FUELS DATA
Thank you, this is EXACTLY what I was looking for. Meth runs at a much richer lambda for max power, hence why we need a lower displayed AFR on the wideband. this will help me make a ton of sense out of what I'm doing before I just stick my finger in the air and take a stab at it
