Is it alright to drive with code P0101
i swaped out my 4.8L with the 6.0L and im getting the code P0101 im still running the 4.8L computer,
my Wheatley pcu will be here on monday but i need to go somewhere tommorow its about an hours drive each way.And can someone on here describe what this code means in some kind of detail,i know what the code is but wanna know why.Thanks
![Icon Confused](https://www.performancetrucks.net/forums/images/smilies2/icon_confused.gif)
P0101-Mass Air Flow System Performance
I have a gauge for that
I wouldnt. The code basically means the MAF isnt working, so you are basically just using the VE table, and since you are using the 4.8 pcm still its not calibrated to the 6.0 and the numbers will be way off.
You may be able to drive it and have the trims help some, but its still a bit risky. Worst case is you run lean and blow it up...
rojeho
08-08-2015 07:20 PM
GreyChevy
07-07-2015 08:57 PM
