Antifreeze & o2 Sensor Damage-Cracked Heads
I have heard that burning antifreeze will damage o2 sensors.
Problem = bad gas mpg after heads replaced.
We have a reg cab 04 Silverado w/5.3 that the water pump went out on, got hot and the heads cracked.
They were a small enough cracks the antifreeze would consume at a quart a day or so. No smoke but stinky.
This went on for weeks while while we fought with the extended warranty Co for coverage. Long story but we got them to cover it.
The o2 sensors were not considered by the dealer for I'm sure.
Now the truck gets a crappy 12 mpg highway.
Any truth to the o2 sensors & antifreeze possible damaging thing? A novice HPTuners owner I would like to ask what, if I can scan and log and tell by the numbers. Would some trims look really off?
We need help finding the gas guzzling problem.
PT's Slowest Truck
Yes, antifreeze can and will contaminate O2 sensors and could cause incorrect readings...if everything else from the head swap is OK (no vacuum leaks or anything like that), there is a good chance that one or both of your O2 sensors have become contaminated with antifreeze
I take it all four would be the way to find out? It's been a while since I've been under there, two pre and two post cats sensors? Or a single after the Y?
Rock auto .com has Bosch units for 43.79 each. The same p/n goes in both sides.
They have 2 NTK's left in stock but are 81.79. Heh!
PT's Slowest Truck
There are 4, but you could start out with the front two, as the rear O2 sensors only account for something like 1% of fueling since their main purpose is to monitor the cats.
I don't like Bosch parts, but I've seen more than one Bosch O2 sensor installed without any problems.
