Any spark plugs better than AC Delco?
Old 11-29-2012, 10:22 PM
  #21
slammedsilvy's Avatar
NGK or AC Delco here as well. Never had an issue.
Old 11-30-2012, 01:06 AM
  #22
The House is Rockin'
BLUES MAN's Avatar
I use 8 zippo lighters. There GREAT.
Old 11-30-2012, 02:10 AM
  #23
Custm2500's Rude Friend
1FastBrick's Avatar
Originally Posted by Slammed96
I'm surprised you like those. I had them in my last truck and it ran like *** with them in. Swapped for some stock style and made a world of difference. Most of the guys I work with steer away from them as well. That's just my .02 on them though.
Originally Posted by DR132
i've found that chevy's are almost always happy with ac delco plugs, ngk's are also good. i've put a lot of autolites in customer's rigs because they're the most readily available at the local parts house and they work but i have had several fail inexplicably. not enough for me to condemn them but they're certainly not my first choice.
Originally Posted by sand man
any body used autolites than me ?
I have always had issues with Autolites. I have had them not work right out of the box, had them fail after there warmed up on a test drive, had them come back any were from a week to a month later when they fail. Even when they don't fail, they deteriorate faster then any other plug. I have never had a happy customer when these plugs were used. There less expensive for a reason.
I can't say I prefer any one specific brand But I always use what came in it from the manufacture and it has never caused me any issues. In some cases customers noticed the difference with new plugs and would call back to thank me or thank me on there next visit. Something that never happened trying to use Autolites.
Old 12-02-2012, 09:35 AM
  #24
Foxxer's Avatar
< Those are better.
Old 12-02-2012, 10:41 AM
  #25
Onetogofast's Avatar
Are E3 plugs really that bad?
Old 12-05-2012, 07:36 PM
  #26
SoSlo07's Avatar
i Used autolites NGK's and delcos. IMO delco is the way to go for N/A motors expensive but worth it. I run NGK's BR7EF at the moment only cause im set up for my 150 shot. but If i go back to N/A im putting another set of delcos in it. I ran a set of autolites for about a week and started having a rough idle and checked the plugs and two were fouled? Checked my tune and codes and nothing was off or wrong. changed to my NGK's and havent had a problem since.
Old 12-06-2012, 11:42 AM
  #27
FormerVendor
KLUG'S SS's Avatar
I sure haven't ever had very good luck with anything but Delco or NGK's. I've tried em all pretty much, Bosch, Autolite etc....... and mileage always seemed to drop and overall the vehicle just did not run or idle like it should.
Champions are good in small engines from my personal experience.
Old 12-06-2012, 09:45 PM
  #28
DR132's Avatar
that's been my observation as well.
twake_410
04-14-2016 09:58 PM
00loudchevy
12-03-2015 05:54 PM
bearden86
26
11-15-2015 03:58 PM
02AWDAWSDenali
10-01-2015 05:08 PM
KleanKustoms
09-30-2015 05:07 PM
Quick Reply: Any spark plugs better than AC Delco?
