for anyone that has never logged TCC MODE...
Old 03-05-2009 | 11:17 AM
  #21
Superado's Avatar
11 Second Truck Club
more...
Originally Posted by Superado
so...anyone's that is NOT locking @ WOT is due to being SD?
Originally Posted by Ed Wright
Nope. They all do that if the tuner doesn't fix it. Tunercat has that table.
Originally Posted by 2xLS1
Not in the Gen 3 cals. Only the older Vortec cals have it.
Maybe I added that to my TC definition files, I have added a lot of things to my TC definition files that no software you buy gives you access to. I'll have to look at a "stock" definition file to know for sure. If not, I'll forward the table locations to TC so it will be included.
But the cals most certainly do have WOT TCC tables, until 2001. 2001 and later do not. 1999 & 2000 4.8, 5.3 & 6.0L trucks, with the LS1 style boxes do.
I looked at a "stock" definition file, it definitely is there. TC has it as two tables (I changed mine to one 2X3 table). The tables in Tunercat are under Transmission Tables, and are labeled "TCC release Speed Vs Gear" and "TCC Apply Speed Vs Gear". No matter what the conditions are the TCC will lock or unlock at the speeds listed in those tables. Most other tuners I talk to call it WOT because the TCC will be locked anyway before the MPH listed there if not WOT. It's difficult to tell if/when a stock TC locks at those speeds, a loose converter shows it right up.
In the transmission calibration file, or "segment" as some call it. You can access it if your tuning software has it. Nothing secret about it. Only 2000 & older calibrations use that table. I have not found it in an '01 or newer cal.
Old 03-05-2009 | 11:30 AM
  #22
Wilde Racing's Avatar
How do I change this text
COME ON DUDE, I just wanted you to post this...
Many truck cals are set to lock @ 75 MPH when WOT. I don't see that table in either EFILive or HPTuners. You often can't feel it lock then with a stock converter.
LOL
NOW, like I said, It must be a EFI issue only, because I have proof other wise...
Old 03-05-2009 | 11:44 AM
  #23
Superado's Avatar
I wasn't being a smartass...I figured I'd just post it here as well...I know some don't like going to linked info...
your's is a later pcm though you said...
Old 03-05-2009 | 11:57 AM
  #24
I know,
I do think it is good info, and thank you for posting it. I just think there maybe a few unaffected models hints why this issuse has shown up before. I'll go through and delete a few worthless posts. I'll post up some logs of my Tcc operation a little later. The big question is, did it fix your issues?
Old 03-05-2009 | 12:05 PM
  #25
charcold-bowtie's Avatar
mine locks.
Old 03-05-2009 | 01:05 PM
  #26
Superado's Avatar
should know by this weekend...
Originally Posted by charcold-bowtie
mine locks.
hmmm...
Old 03-06-2009 | 10:11 AM
  #27
Can any HPTuner guys keep the converter from locking?
Old 03-06-2009 | 10:26 AM
  #28
Superado's Avatar
w/ '99 or '00 pcm...
Old 03-06-2009 | 06:37 PM
  #29
Blown06's Avatar
8 Second Truck Club
Ok, I just went out and logged TCC Mode with HpTuners. My converter does NOT lock up unless I tell it to. There are four Modes that the scanner will show. Off, Apply, Apply En or Locked. You can see at WOT the mode is Apply En not Locked, so I guess this means that it is thinking that it will be locking soon but it does not. Here are the scans. Am I missing something?
File Type: hpl
File Type: hpl
Old 03-06-2009 | 06:41 PM
  #30
KySilverado's Avatar
My converter also locks where ever I tune it to. WOT, part throttle,2nd gear, 3rd gear.... doesn't matter. 03 PCM.
