anyone know how to test cluster without installing?
Do you have the necessary equipment to reprogram them to work in another vehicle? Any test you do will be a failure if the cluster doesn't recognize the new vehicle's VIN.
FormerVendor
Pin --- Wire Color --- Circuit No. --- Function
A4 ------ BRN --------- 41 -------- Ignition 3 Voltage
A5 ------ GRY -------- 1036 ------- Class 2 Serial Data
A6 ------ BLK -------- 1850 -------- Ground
A7 ------ GRY ---------- 8 --------- Illumination Supply Voltage
A8 ------ BLK/WHT ---- 451 -------- Ground
A9 ------ ORN --------- 340 ------- Battery Positive Voltage
A10 ----- PNK -------- 1020 ------- Ignition Positive Voltage
B1 ------ LT BLU ------- 14 -------- LH Turn Signal
B5 ------ PPL/WHT ---- 1382 ------- LED Dimming Signal
B6 ------ PNK ---------- 39 -------- Ignition Positive Voltage
B10 ---- DK BLU ------- 15 -------- RH Turn Signal
2002 - 2006
A6 ------ GRY --------- 1036 ------- IPC Class 2 Serial Data
A8 ------ DK BLU ------ 2115 ------- Right Turn Signal Lamps Supply Voltage
A11 ----- RED --------- 2353 ------- Instrument Panel Lamps Dimming Supply Voltage
A12 ----- BLK --------- 1050 ------- Ground
B1 ------ LT BLU ------ 2114 ------- Left Turn Signal Lamps Supply Voltage
B9 ------ PNK --------- 639 -------- Ignition 1 Voltage (w/o 8S8)
B11 ----- ORN -------- 2840 ------- Battery Positive Voltage (w/o 8S8)
B12 ----- BLK/WHT --- 1851 ------- Ground
2002 - 2006
hartinclay
08-03-2015 07:03 PM
