Anyone switch over to the newer style Card MAF
#27
Well i have everything on order. I got the connector off of ebay, a new IAT sensor and harness from summit. I picked up the IAT sensor just incase i dont like how the IAT sensor response in the new MAF. I got all the couplers and tbolt clamps coming as well.
The u-build-it tube showed up the other day. It is 4in outside diamter which is kinda a bummer. You can see the inside width below. I will say this about the tube, it is THiCK ABS plastic so that is good.
![Name: 97f841a6.jpg
Size: 68.2 KB](https://www.performancetrucks.net/forums/attachments/tuning-diagnostics-electronics-wiring-161/148778d1502131792-anyone-switch-over-newer-style-card-maf-97f841a6.jpg)
Here is the pinout for the MAF incase anyone is interested. The sensor is labeled so it is pretty easy swap
MAF part
Pin A yellow - MAF signal to ECM
Pin B black/white - ground
Pin C pink - ignition 1 voltage from fuse block
IAT part
Pin D tan - low reference from ECM
Pin E tan - intake air temp signal to ECM
MAF part
IAT part
