Anyone use map sensor from 3800 series II supercharged engine?
Would these be a direct bolt in for a 5.3L truck engine with stock intake? Are any of you guys using or are they undesireable for some reason? I have access to one of these sensors at a friends place and figured i would scoop the map if it could be used in my engine. Its going to be a turbo'd 5.3 and plan to run about 10-12psi tuned with HP tuners. If not, what do you guys recommend?
D1SCSS
01-25-2016 10:14 PM
