Anyone use TECH II or similair scanners?
I have HPTuners, but need something that goes further. Been looking into PC based stuff like Autotap and AutoEnginuity. I need something that can read and clear BCM codes. Has anyone used either of these softwares? Do they do as much as a dealership GM Tech II?
Thanks!!!
Thanks!!!
13 Second Truck Club
to be able to read and clear BCM codes your going to be looking at an actual Tech2..and that alone. I dont think that even the higher end Matco, Mac, and Snap-on scan tools can read and clear BCM codes...but I do use a tech2 everyday..
You might look at the EASE scanner, its a PC based OEM scan tool. This difference is you can buy it in modules--PCM, BCM, TCM etc. It will do everything a Tech 2 will do with all the modules including loading GM approved PCM changes, and has EFILiive type logging devise, and wireless scanning.
True, but I want software that does more then just GM vehicles. I'd prefer to cover a many makes and models as I can for shop use. I bought HPTuners because a good friend of mine has EFILive. So we work together on different things.
Cammed4ever
09-30-2015 03:38 PM
