Bad OBDII port??
Old 01-29-2011, 06:49 PM
charcoal03silvy's Avatar
Default Bad OBDII port??
Bought a gauge off a member here that plugs into the OBDII . Works on every vehicle i have tried it on but mine. its got to be my truck. Any ideas?
Old 01-29-2011, 07:10 PM
MikeGyver's Avatar
Did you check your fuse? It's the cig lighter fuse, isn't it people?
Old 01-29-2011, 07:16 PM
Black'Rado's Avatar
cig lighter or accesory? one of the other
Old 01-29-2011, 07:32 PM
which one is that?
Old 01-29-2011, 08:09 PM
03sierraslt's Avatar
Drivers side of dash, pull the panel and look at the fuse diagram.
Old 01-29-2011, 08:16 PM
Pulled the AUX power fuse and it looked like all the rest of em that are working just fine.
Old 01-29-2011, 08:48 PM
scooter k's Avatar
It's the cig lighter fuse in the underhood fuse block that provides power to the ALDL connector
Old 01-29-2011, 09:08 PM
It looked fine, I'll replace it anyhow with an extra I have to see if it works.
Old 01-30-2011, 01:02 AM
traveling mod
andrew383's Avatar
How old is the gauge?? I know some of the earlier ones needed power and some didnt..
The 2 i have in my silvy dont need power run to them but i have an older one that needs 12v for it to turn on...
Did you check to see if it still works on the other trucks you hooked it up to before??
Also what did the seller have it installed in??
Have you posted on the aeroforce forum with this problem???
Old 01-30-2011, 05:23 PM
Doesn't need power. I plugged it into my friend's 99 and my dad's 04 and it worked perfectly fine. Seller's truck was an 01. It is for sure NOT the gauge, its my OBDII port
Quick Reply: Bad OBDII port??
