Bunch of DTC's
Bunch of DTC's
So I have a butt load of DTC's. Which of these should I be concerned about. Check engine light is not on. All of this crap shows up immediately even if I reset them.
[TCM] U1000 - Class 2 Communication Malfunction (History) (Immature)
[TCM] U1255 - Class 2 Communication Malfunction (History) (Immature)
[TCM] C0300 - Rear Speed Sensor Malfunction (History) (Immature)
[TCM] C0305 - Front Speed Sensor Malfunction (History) (Immature)
[TCM] C0306 - (History) (Immature)
[TCM] C0321 - (History) (Immature)
[TCM] C0327 - Encoder Circuit Malfunction (History) (Immature)
[TCM] C0359 - (History) (Immature)
[TCM] C0374 - General System Malfunction (History) (Immature)
[TCM] C0379 - (History) (Immature)
[TCM] C0550 - ECU Malfunction (History) (Immature)
[TCM] B0790 - (History) (Immature)
[TCM] B2725 - ATC Mode Switch Circuit Malfunction (History) (Immature)
[TCM] U1301 - Class 2 Short to Battery (History) (Immature)
[Brake] C0227 - LF Wheel Speed Signal Erratic (History)
[Brake] C0281 - Brake Switch Circuit (History)
[Brake] C0226 - LF Wheel Speed Signal Missing (History)
[Brake] C0225 - LF Wheel Speed Sensor Circuit Open (History)
[Unknown] B0951 - (History) (Immature)
[Unknown] B2610 - (History) (Immature)
[Unknown] B2615 - (History) (Immature)
[Unknown] B2625 - (History) (Immature)
[Unknown] B2948 - Security System Sensor Power CKT High (History) (Immature)
[Unknown] B2961 - (History) (Immature)
[Unknown] U1000 - Class 2 Communication Malfunction (History) (Immature)
[Unknown] U1161 - Loss of PDM Serial Data (History) (Immature)
[Unknown] U1160 - Loss of Communications with DDM (History) (Immature)
[Unknown] U1096 - Loss of Communications with IPC (History) (Immature)
[Unknown] U1152 - Loss Of ACM Serial Data Communication (History) (Immature)
[Unknown] B1440 - (History) (Immature)
[Convenience] U1000 - Class 2 Communication Malfunction (History) (Immature)
[Convenience] B1760 - Driver Seat Asm Rearward Switch CKT Malf (History) (Immature)
[Convenience] B2425 - (History) (Immature)
[Convenience] U1305 - Class 2 Data Link Low or High (History) (Immature)
[Convenience] U1161 - Loss of PDM Serial Data (History) (Immature)
[Convenience] U1160 - Loss of Communications with DDM (History) (Immature)
Take the ground under the cab loose. Its near the cab mount under the drivers door. Clean the frame where it attaches, clean the eyelet on the end of the wire and tighten it back up. When this ground is not making a good connection power can backfeed into your serial data circuit. That will set many of the codes you are seeing. It doesn't have to be loose for this to happen I have seen many trucks that the frame coating insulates well enough that when the bolt gets a little corroded it causes this.
