A/C Pressure R-134a
A/C Pressure R-134a
Whats the low side and the high side suppose to be at on our trucks when the compressor kicks in? and when its off?
I think mine has a bit too much because the pipe closest to the firewall gets hot and i don't think my a/c is as cold as it should be
2000 chevy silverado 5.3
Thanks guys
Thanks guys
The best charge is when the evaporater inlet and outlet are at the same temperature. If the outlet is colder than the inlet it is overcharged, if its warmer its undercharged. Pressures can change depending on ambient temp and humidity.
Oops read that back to myself, don't take the above statement as not needing a gauge. I would NEVER charge an a/c system without one. If you have access to Shopkey, alldata, etc they all have the appropriate temp and humidity to pressure charts.
lukn4trbl355
10-21-2015 11:19 PM
carid
10-01-2015 09:22 AM
lxcoupe
09-25-2015 12:36 PM
