cammed 6.0 help
Un-Registered User
go to the help file in hp tuners to find out how to put it in open loop. do you have a wideband? i cant look at my personal email at work because its a government computer and i cant look at my work email at home because its a personal computer. its prolly a good thing but, a pain in the ***
Un-Registered User
https://www.performancetrucks.net/fo...d.php?t=346549
read this. click on the idle tuning link and start there.also, you might wanna start over from stock.
also, this is a good one from hp tuners. make sure you read all the way down.
http://www.hptuners.com/forum/showth...8776#post78776
ok thanks man, I really appreciate it. I set up open loop thanks to Bill @ HPT and it idles pretty dam good now. On start up it may need a little more or less airflow but I will read thru those links. Thanks man. Looks like I wont be able to tune for a little bit tho so I have some time to ponder and all.
Resident Retard
If it is dying right after you start it up, then it is your startup friction table. if it is not doing it when the truck is cold, but it does it when it is warm/hot, try increase the Hotter areas of that table a little bit. If you increase it to much it will flare BAD at startup and take awhile to come back down...
What size cam and converter are you running? Are you running off your old 4.8 tune? If so did you increase the motor size parameter (I can't remember the name and i don't have software installed on this laptop). Krambo did a idle tuning thread awhile back that really helped me, do a search under his name and idle.... Good luck.
Thanks Corey, that helps alot too. The truck more so doesnt like to run when its hot which I figure out as I was giving AJ his cable back. This whole thing gives me a fuggin head ache and Im not far from buying a mail-order . I keep hearing dont give up and get a wideband instead haha but its frustrating as hell. Charlie Wheatley, however, is fuggin awesome! he mapped me some MAF tables and Fuel Trim where its supposed to be, so as soon as I get my hands on a cable again I will give it a try and see how it works out. I really appreciate all your help guys. Getting more support then over on HPT.
o and btw, no I based it off of a stock 00 Sierra 6.0/4L80e file I picked up on HPT. I am running the Lunati 221/221 .558 114LSA still. It lumps ok in the 6.0 but it wants more
and no converter. Im not real worried about WOT ANYTHING really yet because Im not gonna start flogging it till it has a couple miles, substantial idle tune, and the rest of the exhaust
Un-Registered User
