Check engine light on after engine swap - Stays on after disconnected
Custm2500's Rude Friend
Flash your original 05 computer with a 6.0 tune for an 05 truck.
Sometimes there are changes in the OS that can not be seen with tuning software. A good example is the 06-07 classic DBW tac module, pedal, and TB.
If you try to use an 05 or earlier OS with the 06-07 parts or Vice Versa, It will go into REP mode. The parts and tune must match correctly.
It is a possibility that this is what's wrong with your current setup. It may be a software mis match with the Instrument cluster or the parts on the engine.
Could also be a Vin mismatch as stated earlier.
If you can't find one in the repository, Let me know. I will see if I can supply you one.
Hey Guys, so I threw in the V6 PCM and turned the key forward, then realized that for some reason his truck will NOT show the check engine light unless it is running.
So I tuned the V6 PCM to have all the parameters the V8 PCM does. I then go to start it and it cranks and cranks, and will not start. It is definietly getting fuel - but is not getting spark.
I'm not sure why it will not start with the V6 PCM. The tune is exactly the same as it is with the PCM that the V8 has been running on and even if VATS was the issue - it shouldn't be since this is the PCM that came with the truck originally.
Any tips?
Any tips?
The engine runs perfectly find w/ the older PCM, only issue is the check engine light being stuck on. Not sure why the V6 pcm with the exact same tune would not want to start
