Check engine light on after engine swap - Stays on after disconnected
Old 12-04-2015, 04:36 PM
  #21
Custm2500's Rude Friend
1FastBrick's Avatar
Originally Posted by TXjeepTJ
FastBrick, would you know why the engine isn't getting spark w/ the V6 PCM (with a 6.0L tune flashed to it)?? I read that the PCMs are exactly the same internally, so wiring (as stated earlier) can't be the issue.
The engine runs perfectly find w/ the older PCM, only issue is the check engine light being stuck on. Not sure why the V6 pcm with the exact same tune would not want to start
It's probably a VATS Issue due to a vin mismatch using HP tuners.
Disable the VATS and reflash the tune.
Old 12-21-2015, 08:25 AM
  #22
TXjeepTJ's Avatar
I am having the issue using the V6 PCM, which has the matching VIN. Should I "write entire"? I have been just doing write changes.
I did not flash the V6 pcm w/ a complete V8 tune, I just went into the V6 PCM and changed all the settings to match the V8 settings
Old 12-21-2015, 09:11 PM
  #23
DrX
DrX's Avatar
Then the PCM inputs/outputs will still be functioning as if running the V6. The entire V8 operating system is required to run the V8.
Old 12-24-2019, 07:30 AM
  #24
GREENSIERRA's Avatar
Maybe I missed it but how many miles on the build?
have the rings seated yet?
Old 12-24-2019, 06:01 PM
  #25
darkirish63's Avatar
This is more than 4 years old, brother. I don't think anyone is tracking.
Old 12-28-2019, 11:54 AM
  #26
Former Vendor
Tampa Tuning's Avatar
it does take a while for the rings to seat lol
Old 12-30-2019, 01:18 PM
  #27
Lol
it showed up at the top for some reason, didn't check the date because I thought it was new
Old 12-30-2019, 01:20 PM
  #28
Actually, I dont even remember posting in this, it was supposed to go to a different post.
hmmmm
Old 12-31-2019, 08:53 AM
  #29
MikeGyver's Avatar
It's probably this related thread thing that shows up if you accidentally keep scrolling. You think you scrolled in the thread that you wanted to post, but you are actually in a different thread without going to a new page.
I would have voted against it, but nobody asked.
InsaneDomestics
11-19-2011 02:08 PM
desTRUCKtive
01-17-2008 01:45 PM
SILVERBIRCH
10-23-2007 06:37 PM
z7199
09-06-2005 09:04 PM
alconk
02-12-2005 10:40 AM
Quick Reply: Check engine light on after engine swap - Stays on after disconnected
