Check engine light on after engine swap - Stays on after disconnected
#21
Custm2500's Rude Friend
FastBrick, would you know why the engine isn't getting spark w/ the V6 PCM (with a 6.0L tune flashed to it)?? I read that the PCMs are exactly the same internally, so wiring (as stated earlier) can't be the issue.
The engine runs perfectly find w/ the older PCM, only issue is the check engine light being stuck on. Not sure why the V6 pcm with the exact same tune would not want to start
Disable the VATS and reflash the tune.
#22
I did not flash the V6 pcm w/ a complete V8 tune, I just went into the V6 PCM and changed all the settings to match the V8 settings
#29
It's probably this related thread thing that shows up if you accidentally keep scrolling. You think you scrolled in the thread that you wanted to post, but you are actually in a different thread without going to a new page.
I would have voted against it, but nobody asked.
InsaneDomestics
11-19-2011 02:08 PM
desTRUCKtive
01-17-2008 01:45 PM
