Check out my tune. EFILIVe
Old 01-11-2008, 04:24 PM
Hello Dave
dc_justin's Avatar
Originally Posted by gao8302
The voltage is 0-5 volts. AFR from 10-18.50.
Okay, i'll go ahead and write up a calc_pid for you in a little bit.
Old 01-11-2008, 04:29 PM
gao8302's Avatar
Sounds good. As soon as i get that i will get a log up. thanks
Old 01-11-2008, 05:46 PM
Hello Dave
dc_justin's Avatar
Alright, go to My Documents/EFILive/V7 (or V7.5)/User Configuration and open calc_pids.txt
You'll want it to resemble this:
Code:
# File details
# This section defines various details about the file format.
*FILE
#Parameter  Value            Description
VERSION     7.1.1            File version
DECSEP      .                Decimal separator used in this file
# Units
# See sae_generic.txt for more information on the *UNITS section
*UNITS
#Code     System     Abbr     Description
MPG       Imperial   MPG      "Miles Per Gallon"
# Add slot definitions here
# --------------------------------   ({SAE.VSS.mph})/({GM.INJFLOW.lbpm} *{GM.IBPW1}* {SAE.RPM} * 2 / 6250 )"
# See sae_generic.txt for more information on "SLOT" formats
#Units             Low          High      Fmt  Expression
# MPG
*CLC-00-001
MPG             0.00            99.99      .1   "{SAE.VSS.mph}/({GM.INJFLOW.lbpm} * {GM.IBPW1} * {SAE.RPM} * 4 / 6250 )"
# AEM Ext Input 1
*CLC-00-002
V                  0.0           5.0       .1  "{EXT.AD1}"
AFR               10.0          18.5       .1  "{EXT.AD1}*1.7+10"
# BEN AEM 1
*CLC-00-003
factor             0.0           2.0       .1  "{CALC.AFR_AEM_1.AFR}/{GM.AFR}"
# AEM Ext Input 2
*CLC-00-004
V                  0.0           5.0       .1  "{EXT.AD2}"
AFR               10.0          18.5       .1  "{EXT.AD2}*1.7+10"
# BEN AEM 2
*CLC-00-005
factor             0.0           2.0       .1  "{CALC.AFR_AEM_2.AFR}/{GM.AFR}"
*PRN - Parameter Reference Numbers
# See sae_generic.txt for more information on the *PRN section
#Code                      PRN  SLOT         Units            System           Description
CALC.MPG                   F001 CLC-00-001   MPG              Fuel             "Miles Per Gallon"
CALC.AFR_AEM_1             F002 CLC-00-002   AFR              O2-Wide          "AEM Wideband - Input 1"
CALC.BEN_AEM_1             F003 CLC-00-003   factor           O2-Wide          "Base Efficiency Numerator - AEM 1"
CALC.AFR_AEM_2             F004 CLC-00-004   AFR              O2-Wide          "AEM Wideband - Input 2"
CALC.BEN_AEM_2             F005 CLC-00-005   factor           O2-Wide          "Base Efficiency Numerator - AEM 2"
EDIT: I've also thrown in the MPG PID for you as well.
Old 01-11-2008, 06:13 PM
gao8302's Avatar
Ok i did that but how do i select it now so that i can use it?
Old 01-11-2008, 06:14 PM
Hello Dave
dc_justin's Avatar
You'll need to select External input 1 and/or 2 (whichever your wideband is plugged into on the cable), then the appropriate AEM wideband PID that you just created. Should be in the O2-Wide System pulldown menu.
Old 01-11-2008, 06:20 PM
00Silv4.8's Avatar
dont mean to hijack or anything but how difficult would it be to tune a 4.8 with a 221/221 .558 114LSA? Im looking in to getting a HPTuners possibly since I dont wanna spend the 400 for a dyno tune.. I might anyway, but just wanna get a feel for the difficulty
Old 01-11-2008, 06:24 PM
gao8302's Avatar
still not seeing it. I dont get it. I saved it but i dont see it.
Old 01-11-2008, 07:15 PM
gao8302's Avatar
Its not on the pid pull down menu. The file saved as a txt file. Is this correct. I cant figure it out.
Old 01-12-2008, 09:15 AM
Hello Dave
dc_justin's Avatar
Yes, that is. Let me try and test them today, might be a typo somewhere.
Justin
Old 01-12-2008, 09:35 AM
DrX
DrX's Avatar
Any difference if you uncheck this box?
Quick Reply: Check out my tune. EFILIVe
