Check out my tune. EFILIVe
Hello Dave
Alright, go to My Documents/EFILive/V7 (or V7.5)/User Configuration and open calc_pids.txt
You'll want it to resemble this:
EDIT: I've also thrown in the MPG PID for you as well.
Code:
# ============================================================================== # File details # ------------ # # This section defines various details about the file format. *FILE #Parameter Value Description #---------- ---------------- --------------------------------------------------- VERSION 7.1.1 File version DECSEP . Decimal separator used in this file # ============================================================================== # Units # ------------------- # See sae_generic.txt for more information on the *UNITS section *UNITS #Code System Abbr Description #-------- ---------- -------- ------------------------------------------------------------- MPG Imperial MPG "Miles Per Gallon" # ============================================================================== # Add slot definitions here # -------------------------------- ({SAE.VSS.mph})/({GM.INJFLOW.lbpm} *{GM.IBPW1}* {SAE.RPM} * 2 / 6250 )" # See sae_generic.txt for more information on "SLOT" formats # #Units Low High Fmt Expression #------------ ------------- ------------- ---- -------------------------------------------------------------- # MPG *CLC-00-001 MPG 0.00 99.99 .1 "{SAE.VSS.mph}/({GM.INJFLOW.lbpm} * {GM.IBPW1} * {SAE.RPM} * 4 / 6250 )" # AEM Ext Input 1 *CLC-00-002 V 0.0 5.0 .1 "{EXT.AD1}" AFR 10.0 18.5 .1 "{EXT.AD1}*1.7+10" # BEN AEM 1 *CLC-00-003 factor 0.0 2.0 .1 "{CALC.AFR_AEM_1.AFR}/{GM.AFR}" # AEM Ext Input 2 *CLC-00-004 V 0.0 5.0 .1 "{EXT.AD2}" AFR 10.0 18.5 .1 "{EXT.AD2}*1.7+10" # BEN AEM 2 *CLC-00-005 factor 0.0 2.0 .1 "{CALC.AFR_AEM_2.AFR}/{GM.AFR}" # ============================================================================== *PRN - Parameter Reference Numbers # -------------------------------- # See sae_generic.txt for more information on the *PRN section # #Code PRN SLOT Units System Description #------------------------- ---- ------------ ---------------- ---------------- ------------------------------------------ CALC.MPG F001 CLC-00-001 MPG Fuel "Miles Per Gallon" CALC.AFR_AEM_1 F002 CLC-00-002 AFR O2-Wide "AEM Wideband - Input 1" CALC.BEN_AEM_1 F003 CLC-00-003 factor O2-Wide "Base Efficiency Numerator - AEM 1" CALC.AFR_AEM_2 F004 CLC-00-004 AFR O2-Wide "AEM Wideband - Input 2" CALC.BEN_AEM_2 F005 CLC-00-005 factor O2-Wide "Base Efficiency Numerator - AEM 2"
