Code Help.....
Moderately Differentiated
Seems to be a thing these days, those codes. Jesus Shannon, that's a **** load of diagnosing.
Seems from research I've done and those above diagnoses say the same thing. Clean the grounds for your EBCM. I have those codes (not exactly but for the most part) and I'll tell ya, a PCM didn't fix mine.
Originally Posted by dewmanshu
yes, yes sir this is correct most of the time, except for ADD ******* like me.
THERES ALWAYS AN EXCEPTION TO THE RULE
so where do I find this ground? Is that the box under my driver side that causes the abs pump to run all the time when it goes out?
the ground you need is under the drivers door. It is bolted to the part of the frame that holds the body mount bolt. It is the one with 2 wires going to it. Just clean off the goop, and put a star washer under it, and tighten it.
Well I cleaned the battery terminals and changed the pcm. Problem solved. Not sure what fixec it but it hasent done it in 4 days and it was doing it everyday.
Im going to check out the PCM to see if that was the problem -- if it wasent then I will have one for sale soon
