Code P0106 - MAP sensor
I'm getting code P0106. The only time that I get this code is I turn key, and start driving when the engine is "cold." After it's warmed up, it'll go away. On a cold start; if I let the engine warm up for 2-3 min, then it's fine/ok.
What's the differences in the two. I have no EGR, so I don't see if there's anything that warms up in the intake. I just did a motor swap and had no prior issues with any codes at all. Again, this only happens when I cold start, and start driving, never once it's warmed up. The engine is a 6.0 with a 222/224 -112 cam.
Originally Posted by foff667
theres a few sanity checks within the pcm...your probably just out of range at cold startup...should be able to be tuned out with no ill effects though.
"tuned out" . . . do you mean " do not report" or just delete it out?
forgive me I know nothing about the tuning side.
Tydriver
45
10-23-2015 09:19 PM
muncie21
09-07-2015 09:55 PM
