Codes to delete for Vac Mod?
What codes need to be deleted when doing the Vacuum mod on a 4l60e? The kit i have has the resistor to install which im guessing is to trick the computer.. but wasnt sure. Either way, what codes need to be deleted or what else needs to be changed? Thanks in advance!
11 Second Truck Club
Its been a few yrs since I did mine but don't bother with the resistor-just go in and turn off the codes associated with the PCS. I cant remember how many there were (2 or 3 Im thinking)
I assume you are doing this mod because you are boosted? If so, dont forget to install the little check valve thingy to vent off some of the pressure under boost or you will damage the vac modulator.
cant find anything about the force motor... not sure on what to delete still after looking at this... this is all the tranny dtc codes:
P1700 Transmission MIL Request
P1701 Transmission MIL Request Circuit
P1705 P/N Signal Output Circuit
P1740 Transmission Torque Reduction Request Circuit
P1743 TP Signal From ECM
P1760 ECM Supply Voltage Interrupted
P1779 Engine Torque Delivered To TCM Signal
P1780 Park/Neutral Postion (PNP) Switch Circuit Engine Torque Signal Circuit
P1790 Transmission Control Module Checksum
P1791 Transmission Control Module Loop
P1792 Transmission Control Module Reprogrammable Memory
P1793 Transmission control Module Stack Overrun
P1795 CAN Bus-Throttle Body Position
P1800 TCM Power Control Relay Circuit Open
P1801 Performance Selector Switch
Failure
P1804 Ground Control Relay
P1810 TFP Valve Position Switch Circuit
P1811 Maximum Adapt And Long Shift
P1812 Transmission Over Temperature Condition
P1813 Torque Control
P1814 Torque Converter Overstressed
P1815 Transmission Range Switch-Start In Wrong Range
P1816 TFP Valve Position Switch-Park/Neutral With Drive Ratio
P1817 TFP Valve Position Switch-Reverse With Drive Ratio
P1818 TFP Valve Position Switch-Drive Without Drive Ratio
P1819 Internal Mode Swtich No Start, Wrong Range
P1820 Internal Mode Switch Circuit A Low
P1822 Internal Mode Switch Circuit B High
P1823 Internal Mode Switch Circuit P Low
P1825 Internal Mode Switch Illegal Range
P1826 Internal Mode Switch Circuit C High
P1831 PC Solenoid Power Circuit Low Voltage
P1833 A/T Solenoids Power Circuit Low Voltage
P1835 Kick-Down Switch
P1836 Kick-Down Switch Failed Open
P1837 Kick-Down Switch Failed Short
P1842 1-2 Shift Solenoid Circuit Low Voltage
P1843 1-2 Shift Solenoid Circuit High Voltage
P1844 Torque Reduction Signal Circuit Desired By TCM
P1845 Transmission Gear Ratio Output Circuit
P1847 2-3 Shift Solenoid Circuit High Voltage
P1850 Brake Band Apply Solenoid Circuit
P1851 Brake Band Apply Solenoid Performance
P1852 Brake Band Apply Solenoid Low Voltage
P1853 Brake Band Apply Solenoid High Voltage
P1860 TCC PWM Solenoid Circuit Electrical
P1864 Torque Converter Clutch Circuit
P1868 Transmission Fluid Life
P1870 Transmission Component Slipping
P1871 Undefined Gear Ratio
P1873 TCC Stator Temp. Switch Circuit Low
P1874 TCC Stator Temp. Switch Circuit High
P1875 4WD Low Switch Circuit
P1884 TCC Enable/Shift Light Circuit
P1886 Shift Timing Solenoid
P1887 TCC Release Switch Circuit
P1890 ECM Data Input Circuit
P1891 Throttle Position Sensor PWM Signal Low
P1892 Throttle Position Sensor PWM Signal High
P1893 Engine Torque Signal Low Voltage - Read Our Article on Automotive Circuit Testing For Help With This Chevy Check Engine Light Code
P1894 Engine Torque Signal High Voltage - Read Our Article on Automotive Circuit Testing For Help With This Chevy Check Engine Light Code
P1895 TCM To ECM Torque Reduction Circuit - Read Our Article on Automotive Circuit Testing For Help With This Chevy Check Engine Light Code
Failure
GM1697
09-09-2015 01:52 PM
muncie21
09-07-2015 09:55 PM
