Cold Start Up
Old 01-01-2011 | 06:48 PM
  #21
MikeGyver's Avatar
Not if the leak quit when the parts warmed up, expanded, and seal the leak.
Old 01-01-2011 | 06:50 PM
  #22
viciousknid's Avatar
Where's the Beef?
technically all it means is the driverside o2 before the cat is reading a lean condition. Could be that the sensor itself is faulty and reading incorrectly. You could have a vacuum leak causing bank 1 to go lean.
Swap the driver side sensor with the passenger side sensor and see if the code changes to bank 2. If it does it's the sensor, if it does not then it's likely vacuum or other.
As mike just said, If it's a vacuum leak (especially on the intake) the material will expand at a certain temp and seals off the leak.
  #23
MikeGyver's Avatar
Your asking if the sensor is bad is the same as saying, "man, is it cold outside. I must need a new thermometer".
Old 01-01-2011 | 06:53 PM
  #24
rel3rd's Avatar
11 Second Club
Originally Posted by bmd_CL
It wont die all the time, it only died once...itll just rev way down where its barely running like its being starved for fuel, and if it was a vacuum leak wouldnt it run bad all the time, not just on the first start up of the day?
Not necessarily. My wife's SUV was acting much like you describe your truck. Once it warmed up it ran fine. Vacuum leak was still there, obviously, but I guess the PCM was "learning" to run the best it could with the problem. Hers never got a check engine light until it got even worse....as luck would have it, I couldn't find the damn leak until it did get worse.
Like the guys above posted, check for vacuum leaks around the intake and all the hoses. It's simple and cheap enough to do, and either confirms or eliminates the diagnosis that some of us are guessing on.
Old 01-01-2011 | 07:27 PM
  #25
bmd_CL's Avatar
so check the vacuum lines and if that doesnt fix it swap the driver side front o2 to the passenger side front and see if it switches over to bank 2?
Old 01-02-2011 | 06:42 PM
  #26
bmd_CL's Avatar
Driver side o2 sensor is what it was...pulled it out and it looked all sooty. Tested it and when warm only put out about .1 volts... .6 is what its supposed to be. Runs good now
  #27
bmd_CL's Avatar
Thanks for the help btw
Old 01-02-2011 | 06:52 PM
  #28
Where's the Beef?
Glad it was something simple. Intakes are a bit more work.
Old 01-02-2011 | 08:43 PM
  #29
bmd_CL's Avatar
Yes me too. I really didnt wanna pull the intake off...Thank all of you for your help
Old 01-16-2011 | 10:10 PM
  #30
Dixon79lt's Avatar
my truck is doing the exact same thing.. only it reads lean banks 1 and 2.. so i dont think its both 02 sensors, i ran it on the scanner and they both responded fine. the trims look ok. i sprayed carb cleaner around the intake and it didnt have any reaction... the only thing i can think of is maby a service bulliten?? anyone ever heard of this?
treylittlefield
01-24-2016 08:38 PM
Mossyoakglock
08-28-2015 01:49 PM
superchomper2003
08-26-2015 10:39 AM
Mossyoakglock
07-17-2015 09:30 AM
GRRR65GTO
07-10-2015 09:27 PM
Quick Reply: Cold Start Up
