completely stumped, 6.0l truck engine problem
Old 10-08-2012, 10:15 PM
OneBadRR's Avatar
Originally Posted by TXSZ66AVLANCHE
No, but AFM will keep valves from opening.
Specifically intake valves I assume, so I'd rule out AFM as the cause.
Old 10-08-2012, 10:26 PM
Custm2500's Rude Friend
1FastBrick's Avatar
Did you do a crank relearn after the engine replacement???
Old 10-08-2012, 10:36 PM
darkostoj's Avatar
sure did!
Old 10-09-2012, 12:01 AM
Cam and crank installed dot to dot?
Did you happen to check fuel pressure.
Is this a 2007 NBS or NNBS truck. IF NNBS are you positive it's a 58X crank I really don't know how the pcm would respond with the older crank hell it may not even start if it was not a 58x crank.
Old 10-09-2012, 12:13 AM
11 Second Hall Moniter
AKlowriderZ71's Avatar
......finish doing the compression test.
Old 10-09-2012, 12:44 AM
I have a gauge for that
Atomic's Avatar
Are you sure its a backfire and not a misfire? Kind of sounds like wrong injectors/ injector data, but either way a fuel issue.
Old 10-09-2012, 10:40 AM
dmelvin's Avatar
Originally Posted by darkostoj
Any way to check if the ecm is good/bad?
Only way I know is to swap it with a known good one. Did you do a VVT delete when you put fresh heads on it? If so, did you delete VVT from the ECM?
Old 10-09-2012, 12:10 PM
darkostoj's Avatar
didnt touch the vvt, left everything stock.
did the crank sensor relearn
checked all the fuel injector pulses and they are good
double checked all grounds
exhaust not plugged
swapped #1 o2 sensors from left to right bank, no change
changed the bad bank 1 rear 02 sensor and its working now, no change, and now there are no trouble codes
the short term and long term fuel trims are all at 0% (not sure if this is normal)
put in new plugs
old and new engine were both 58x wheels
ordering new spark plug wires now even though i doubt thats the problem
drained old gas and put in fresh gas
map sensor is good
maf sensor is good
throttle body is good
coolant temp sensor is good
oil pressure sensor is good
all 4 02 sensors are reading correctly
coils are good
fuel pressure is good and steady. Will fluctuate a small amount when struggling to idle
did compression test on all cylinders except #8 because it was hard to get to. All are 210 on the dot
Old 10-09-2012, 12:42 PM
Gordy M's Avatar
Use a scan tool to determine if you are getting missfires and if so which cylinder(s). Then you could pinpoint it at to valves, electric, etc.
Old 10-09-2012, 02:17 PM
darkostoj's Avatar
ugh, cracked intake manifold
Quick Reply: completely stumped, 6.0l truck engine problem
